mn6 to mn12
Old Dec 17, 2007 | 08:43 PM
roysvett's Avatar
roysvett
Default mn6 to mn12
is the c5 mn6 to mn12 a direct swap with no problems and no issues I am trying to do th this week end and the dealer is not open.help
Old Dec 17, 2007 | 09:02 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Should be a direct swap. The biggest difference of the two transmissions is the internal gearing.
Old Dec 17, 2007 | 09:28 PM
roysvett's Avatar
roysvett
i hope u r right it is going in this week end
Old Dec 17, 2007 | 11:23 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
Mn12???
Old Dec 18, 2007 | 03:12 AM
bobby1999c5's Avatar
bobby1999c5
I've done the swap with no problems.
Bobby
Old Dec 18, 2007 | 06:02 AM
SJSZ06's Avatar
SJSZ06
Originally Posted by Joe0121
Mn12???
Z06 transmission.
Old Dec 18, 2007 | 09:39 AM
RAFTRACER's Avatar
RAFTRACER
Direct swap no issues..............
Old Dec 18, 2007 | 11:22 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
No issues whatsoever
Old Dec 18, 2007 | 11:50 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Only difference other than gearing, is the standard C5 does not have a connector for the trans temp light (i.e filler plug), so just swap them out.
Old Dec 18, 2007 | 07:14 PM
Joe0121's Avatar
Joe0121
St. Jude Donor '06
Originally Posted by SJSZ06
Z06 transmission.
Why is it called an MN12? and would a simple rear end swap or is sixth the same ratio between the two?
Old Dec 18, 2007 | 08:22 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Tranny is either a MN6 or M12, their is no MN12. A gear swap in the rear to 3.90's would probably bring you on par gear wise with M12 if you had a MN6.
Cars with FI should probably stick to 3.42 or less, due to traction.
Old Dec 18, 2007 | 09:00 PM
DRR's Avatar
DRR
I did the swap a couple of years ago when my MN6 failed. One thing slightly different is the shift linkage connection at the trans. I think we had to drill out one side slightly larger. You will see when you do it, and it is easy.
Old Dec 18, 2007 | 11:59 PM
coanan's Avatar
coanan
http://www.zo6vette.com/forums/showthread.php?t=60015
M12 6-Speed Manual
This transmission is unique to the Z06, and is the only transmission available for that model. It is not available on Corvette coupes or convertibles. It has more aggressive gearing to increase torque multiplication in most forward gears, allowing for more rapid acceleration and more usable torque at higher speeds.
A transmission temperature sensor was added to protect the M12 from higher thermal stresses. The sensor warns the driver via the Driver Information Center with a TRANS OVER TEMP light if thermal loads become excessive, meaning that the transmission could be damaged if not allowed to cool down.
Gear Ratios
LS1/MM6 LS6/M12
1st Gear 2.66:1 2.97:1
2nd Gear 1.78:1 2.07:1
3rd Gear 1.30:1 1.43:1
4th Gear 1.00:1 1.00:1
5th Gear 0.74:1 0.84:1
6th Gear 0.50:1 0.56:1
Reverse 2.90:1 3.28:1
Old Dec 19, 2007 | 12:28 AM
TYSON1997's Avatar
TYSON1997
DRR is right when you hook up the shift linkage to the tranny the hole in the shifting input shaft is to big. You have to drill the hole out on the shift linkage to the same size as the shiftting input shaft and use a bigger pin. Very easy to do though, you can just measure the hole and go to lowes or home depot and find a pin that is the same size as your drill bit. Also while you are in there you may want to do a clutch if you plan on adding more power or at least a slave cylinder and remote slave cylinder bleeder.
Old Dec 19, 2007 | 03:07 AM
RAFTRACER's Avatar
RAFTRACER
I have flip-flopped back and forth many of M12's and MN6's on various cars and have never came across this shift linkage pin diameter issue...............
Old Dec 30, 2007 | 12:39 PM
roysvett's Avatar
roysvett
Danny do you have any zo6 trans or will you build mine it wont stay in 3rd gear or 1 st. adjusted the shifter box on the torque tube and even bought a new one .
Old Dec 30, 2007 | 01:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You probably have bad fork pads.
http://rpmtransmissions.com/rpmupgra...ronzepads.html
To mn6 to mn12
Old Dec 30, 2007 | 01:12 PM
RAFTRACER's Avatar
RAFTRACER
Yes.......call me and bring it......I currently have my cell on me....
Old Dec 30, 2007 | 05:22 PM
SpinMonster's Avatar
SpinMonster
Actually they should gear for the trap speed and stop adding power when they cant get the power to the ground anymore. 60's fall with gearing. Gears slow the rotation speed of the tire which lets you hook faster (actually it hooks when the car reaches the speed that the tire rotation is at).
Old Dec 30, 2007 | 06:12 PM
DRR's Avatar
DRR
I replaced a '98 MN6 with an '05 M12 and found this issue upon close inspection. The male end can be seen in the left side of this pic...
The male and female linkage couplers are different sizes. I had to drill it out and use a larger pin than what my '98 originally had.
They must have changed this sometime after my 3/98 build date.
If you have not swapped a 3/98 or earlier MN6 to an '05 M12 - may explain why you may not have seen it.
