Did Not Start
Old Dec 18, 2007 | 11:33 AM
slowerlowerdel's Avatar
slowerlowerdel
Default Did Not Start
Sitting a mall parking lot and tried to start my 99. Engine fired and quit twice. Turned key off and tried again and everything was fine. No codes set. Any comments?
Old Dec 18, 2007 | 11:35 AM
CODE4LS1's Avatar
CODE4LS1
Sounds like either your VATS or fuel pump quit.
Old Dec 18, 2007 | 12:16 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Next time it happens watch the "security" light to see if it's on steady or if it's flashing, the flashing would indicate a VATS problem.
VATS stands for Vehicle Anti Theft System, everytime you insert your ignition key in the resistor or pellet that is on the key is read by the BCM to make sure it is correct, if it's not correct the BCM triggers the "security" light to flash.
Old Dec 18, 2007 | 12:55 PM
FireLieutenantPhilly's Avatar
hmmm may have happend to me yesterday.
To Did Not Start
