Flycutting Tools
Old Dec 18, 2007 | 08:06 PM
thetorch's Avatar
thetorch
Default Flycutting Tools
Here are some pictures of the Lindy Tool In Head Piston Cutters (IHPC). I have no connection to the company that manufactures these other than a satisfied user. They are great tools and I wanted to share another option available for in-block piston flycutting.
Features:
1. Will fit in a disassembled head, down to the valve seat without modification to the cutter or head.
2. Provide a radius cut in the piston
3. Radial clearance built into the cutter, typically .090
4. Come in exact valve sizes for an exact fit
5. Manufactured of M-2 tool steel for long life, can be resharpened if you cut that many pistons
6. Guide rods available in metric sizes, i.e. 8mm for LSx engines
7. The back side of the cutter is shaped like a valve to reduce the chance of damage to the valve seat and valve job
8. Guide rod stops for setting cutting depth
Dave Lindy is a super nice guy that has some great information to share. He makes the tools himself and will do custom configurations if requested.
Pictures: (These are 2.055 and 1.60 IHPC's in a Dart 225cc head)
Flycut pistons with IHPC:
Last edited by thetorch; Jan 4, 2008 at 02:18 PM. Reason: Added pictures of flycut pistons
Old Dec 18, 2007 | 09:03 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Very and hopefully priced better than than the Isky cutters.
(not that I have a need for them anymore).
Old Dec 18, 2007 | 10:40 PM
thetorch's Avatar
thetorch
They are priced as follows:
Cutter: $78.50 (Valve size specific)
Guide Rod: $28.00 (Valve guide size specific)
If you needed to cut both intake and exhaust and wanted to do both at the same time, you would purchase the following:
2 valve size specific cutters
2 valve guide size specific guide rods
or you could buy one guide rod and swap cutters for each valve.
Old Dec 19, 2007 | 06:13 AM
vettenuts's Avatar
vettenuts
Very nice, how do you set depth?
I notice some "Dart green tape" in the pictures too
Old Dec 19, 2007 | 07:08 AM
Greg_E's Avatar
Greg_E
The stop collars are shown in the 8th picture.
Old Dec 19, 2007 | 12:31 PM
thetorch's Avatar
thetorch
That's right, those are the 225's that I'm installing next week.
As already noted, the tools come with collars to set the depth.
Old Dec 19, 2007 | 06:48 PM
vettenuts's Avatar
vettenuts
Make sure you take plenty of photo's. Those cutters are very nice
Old Dec 19, 2007 | 07:51 PM
TLewis4095's Avatar
TLewis4095
Nice price to
Old Jan 4, 2008 | 02:18 PM
thetorch's Avatar
thetorch
Update: I added pictures of flycut pistons using the IHPC, see post 1.
Old Jan 4, 2008 | 04:00 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
How deep are you cutting them? Doesn't look like a lot.
I cut mine .100" deep.
Also, be sure to sand down the sharp corners of the cuts before you call it done.
Old Jan 4, 2008 | 05:28 PM
thetorch's Avatar
thetorch
Your correct, I only needed .040" on the intake side. Will do on sharp edges.
To Flycutting Tools
