I plan to install ported LS6 heads on my LS1 and install headers at the same time. With the heads off, can I put the headers in from the top without issue? Seems like there should be plenty of room with them off.
If only all header installs could have the heads off it would be a lot simpler!
You will be happy doing it with the heads off and it will be much much easier!
Thanks,Matt
Reason: correct word off
Thanks,Matt
Originally Posted by flasunshine1
Do it with the heads off, you'll be glad you did.
Originally Posted by Sleazy Rider
i ended up dropping the cradle to get my headers back in.
Cool. then I'll wait to install the headers until I am ready to put everything else on. I was sure it would be easier to install, I just wasn't sure I could do it from the top.
