help with my new C5
Old Dec 22, 2007 | 03:01 PM
FantasticPlastic's Avatar
FantasticPlastic
Default help with my new C5
Hi , Im noticing stuff everyday and since the weathers **** in NJ , Its hard to see everything that might need attention. I noticed my fenders at the bottom were they bolt to the rocker---the plastic has split and they are not secure (But dont move easily) Is this from a mistake jacking the car up or a bodyshop that didnt know a bolt was down there ----and my passenger door handle is loose and the very bottom of door is out a 1/4 inch from the rocker --the drivers side is perfect ----this a big deal, door hinges and bolts look unturned and not repainted
Old Dec 22, 2007 | 05:40 PM
Vettedreamer2's Avatar
Vettedreamer2
The cracking is most likely from a lift. You are suppose to use jacking puck so the arms of the lift don't push against the body. Not sure on the handles. Did you do a search? That tool is awesome. Good luck
Jason
