There is a minor problem with removing what is referred to as the "demon key". Basically, when you remove the little plastic plate that shows the shift pattern, if you look into the cavity, toward the rearmost part there is a small rectangular metal pin. This pin is in the shape of a "T" with the bottom sticking down the shifter shaft into a groove. You have to pry this pin out first and then unscrew the shift ****. A search for "demon key" will turn up some good suggestions for removal.
As mentioned in the following post by Dave68, the needle nose visegrips will prevent any damage being done to the ****. The jaws of the needlenose visegrips can twist and chew up the key, so after I clamp them on the key, I clamped a second set of regular vise grips on the jaws to keep them from twisting.
One note on the vise grip screw driver method. Have someone hold something (board?) above the vise grips so they don't fly up and hit the windshield. If you have a particularly stubborn key you are putting a lot of pressure to it when it finally lets go.
On a good note, I'm finally getting that little tiny chip in my windshield fixed
This is why I advise people to use the hammer-tapping method with the long-neck visegrips. The screwdriver/lever arm method is more dangerous, once the key disengages.
Agreed, probably the safer method. Read both and didn't think about the safety when choosing to pry it. It wouldn't budge until I gave it that little extra effort but man it flew then Great way to start what's going to be a long weekend. New clutch going in along w/ shifter and long tubes. Hopefully the only carnage of the weekend.
