Headlight Issue
Old Dec 23, 2007 | 01:19 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default Headlight Issue
Having an issue with the left headlingt. Sometimes all is well, sometimes when you turn the headlights off the left will go down, then halfway back up and stop. Then when you turn the lights on again the left one will go down and the right one up. Then, sometimes when you turn it off it will go up and down several times before finally picking one. Is this a motor issue or what? ground? BCM? or is there a headlight module ala C4?
Old Dec 23, 2007 | 04:22 PM
rcknusa's Avatar
rcknusa
Mine did the same thing a while back. I ended up finding a TSB here on the forum about it. I will look again but it all boiled down to several washers on the left headlight unit. I replaced the gears for the 2nd time too but I think the half up and down was purely the TSB.
Old Dec 23, 2007 | 04:28 PM
rcknusa's Avatar
rcknusa
Default here is the TSB
Number: 00-08-42-002
Subject: Left Headlamp Door Does Not Stay Closed (Shim Headlamp Door Motor/Actuator and Replace Insulators)
Model Year: 2000 Chevrolet Corvette
Condition
Some customers may comment that the left front headlamp door does not remain closed after the headlamps are turned off. Others may comment that the left headlamp door closes when the headlamps are turned off, but then reopens. In either case, the right headlamp door operates properly.
Correction
Important
The following information applies to the left front headlamp door motor/actuator only. It does not apply to and should not be performed on the right front headlamp door motor/actuator.
Install one washer (2) between the left headlamp door motor/actuator (1) and the mounting bracket (3) at each of the three attaching bolt locations. Also replace the
insulator (4) on each of the two mounting bracket travel stop tabs (5) as shown. For information on headlamp motor/actuator removal, see the Headlamp Motor/Actuator
Replacement procedure in the Lighting sub-section of Body & Accessories in the appropriate Service Manual.
Parts Information
Part Number Description Qty Per Vehicle
11505463 Washer 3
16524060 Insulator 2
http://forums.corvetteforum.com/show...ight=headlight
see the link for a picture. Good luck.
Old Dec 23, 2007 | 07:52 PM
corvettedoug's Avatar
corvettedoug
Condition
Correction
Important
Parts Information
11505463 Washer 3
The first time I was just lazy and replaced only the stopper. About three months later, I had to do it all over again with the washers. I would suggest doing both the washers and stopper.
Old Jan 2, 2008 | 02:20 PM
av8rdavid's Avatar
av8rdavid
I did this fix and still no dice....At first it was my left headlight now BOTH are inop..Won't go up or down unless i manually turn them.
Old Jan 8, 2008 | 04:25 AM
av8rdavid's Avatar
av8rdavid
I'm starting to think the problem is the MODULE which i have no clue where it can be...Anybody?
Old Jan 11, 2008 | 02:09 PM
Harry Bilgewater's Avatar
Harry Bilgewater
Default Had the same problem
I had the same failure on my left headlamp assembly. It was the plastic gear in the headlamp motor assembly. The plastic cogs break off. You can use the manual **** to reset the headlamp to the proper position and soon as you turn it on again the headlamp will open partially or not close properly. You will likely notice even when the headlamp is extended it is not solidly in place.
I ordered a metal gear kit to repair the assembly from a guy on e-Bay. The repair involved removing the motor assembly. It is something of a PITA but can be done from the top side.
The motor is sealed in a plastic housing and you have to literally crack it open. I used a Dremel tool with a cutting disc. When gluing it back together the kit instructions say the glue is adequate to hold the two parts together but mine cracked apart after a few weeks. I took it down again and drilled holes through the edges of the plastic case parts at about a 45 degree angle. I then ran aircraft safety wire (pretty much any small diameter steel wire will work) through the holes, twisted it to lock the plastic parts in place and reglued with epoxy.
It has been inservice for two years now with no further problem.
Post mortem of the old gear showed discoloration of the plastic where two of the cogs had broken off. Not sure why it discolored. The gear kit was about $35.00. The replacement motor from the dealer was around $600.00 and they would have to order it.
Old Jan 12, 2008 | 06:49 AM
jdmvette's Avatar
jdmvette
Night Owl for life
if you've replaced the gears in the past, check that the lid hasnt popped off. if it has, most likely the actuator arm is not stopping at the tab and is causing the door to pop back up when turned off.
Old Jan 12, 2008 | 12:06 PM
Esquire0303's Avatar
Esquire0303
Default Headlight issues
I ran into these symptoms on my Z06 at about 55 K miles, did (and re-did) the plastic to brass gear swap, carefully following the instructions and tips from other Forum members frustrated with GM's pop-up light fiasco, but still had a case of "Popeye."
I then dug my hole deeper with one of TBYRNE's late, unlamanted, infernal HID kits. But in the 8-hour process of rewiring and installing the new harnesses discoverd a critical ground point low down on the passenger side. I dutifully removed the lead, scuffed and cleaned the tip of the lead, plastic clip and mounting point with isopropyl alcohol, applied battery anti-corrosive, buttoned her back up, and sure enough, my problem was solved.
(BTW, those HIDs are fantastic, but what a pain in the [expletive] to get them installed and working "right," with both the HID lows illuminating along with the halogen highs when the high beams are selected. Unfortunately for those of us with gray hair and diminished night vision, Tom Byrne, who is a great guy standing behind a reputable business and great products, pulled these lights from his catalog in the face of complaints and frustration with wiring and installation issues. )
This may not be the silver bullet for your particular version of Popeye, but it can't hurt. And this step may be prophylactic against future electrical problems with your lights. I actually did the same procedure on every ground point I coulld find (and reach) while I was at it, investing more than 2 hours in the exercise, following the lead of another astute Forum member way, way above my shade-tree paygrade.
Good luck.
To Headlight Issue
