ls6 intake install
Old Dec 25, 2007 | 01:50 AM
largeitalian's Avatar
largeitalian
Default ls6 intake install
Do I need all the ls6 fuel rails and coolant lines when throwing an ls6 intake onto an ls1 or is it just switch and go?
Old Dec 25, 2007 | 04:53 AM
SLPRC5's Avatar
SLPRC5
You can use the LS1 fuel rails, but you will need the LS6 coolant lines.
Old Dec 25, 2007 | 05:15 AM
danziger's Avatar
danziger
Exactly right. Be careful of the fittlings/tubing at the back of the intake when removing. Also, don't over-torque the bolts. It is a pretty easy job that I did on my Z28 in about an hour and the F-body has 1/2 the engine under the cowl...
Old Dec 25, 2007 | 09:04 AM
2079's Avatar
2079
How about gaskets ?
Old Dec 25, 2007 | 09:37 AM
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
St. Jude 15 Year Donor
St. Jude Donor '08 thru '26
Originally Posted by 2079
How about gaskets ?
Most of the time you can reuse the intake manifold and throttle body gasket several times before replacing them..I recently bought a new LS6 Intake kit from GM.This kit includes the intake manifold, intake seal P/N 12560251, intake manifold gasket kit P/N 12533587, throttle body seal P/N 12552542, map sensor P/N 16212460, map sensor seal P/N 16194007.
Sometimes also I've had to replace some of the injector O-Rings because they can get buggeried up during the swap..
Old Dec 25, 2007 | 11:30 AM
American Hydrocarbon
Guest
Posts: n/a
You will also need the coolant pipe set up for the LS6. GMpartshouse.com
Good luck with the swap.
Old Dec 25, 2007 | 12:56 PM
largeitalian
ive heard you can grind down the intake so that the ls1 coolant lines work?
Old Dec 25, 2007 | 01:03 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
This will help - But no you do not need the LS6 fuel rail
http://www.ls1howto.com/index.php?article=5
You will need the coolant lines for the LS6 set-up!
Thanks,Matt
To ls6 intake install
