Mild Computer Reset?
Old Nov 26, 2001 | 06:47 PM
Vette XP's Avatar
Vette XP
Default Mild Computer Reset?
I think I've seen others post about similar occurrences, but I can't find anything via the search.
I jumped in the vette this morning and I noticed that some of my settings had been reset. For example, the average fuel mileage was reset to 0, and my HUD settings were reset to all on. Other settings like my tripodometers were not reset.
I'm the only driver (it's my daily driver), and the the last time I took it out was Saturday night.
Is this an indication of a problem?
Old Nov 26, 2001 | 06:56 PM
C5Cemo's Avatar
C5Cemo
Default Re: Mild Computer Reset? (Vette XP)
It can't be good but it's probably the battery cable connections. I'd disconnect them and check for debris/corrosion. You still got the original battery?
Old Nov 27, 2001 | 12:26 AM
WestCoastCorvette's Avatar
WestCoastCorvette
Supporting Vendor
Same symptoms we have had on the start of a BCM problem
Old Nov 27, 2001 | 12:47 AM
bparker's Avatar
bparker
If you have a son, I would hide your keys better... :lol:
Old Nov 27, 2001 | 12:55 AM
WMW's Avatar
WMW
Before you disconnect your battory cables,perform a diagnostic systems check and see if there are any stored codes.As noted you may have a BCM problem that could be due to water leaking onto(into)you BCM case.Have your HVAC-drain hole checked for any signs of dirt,allowing water to back-up in the case.Wm
To Mild Computer Reset?
