Help on which catch can to buy.
Old Dec 26, 2007 | 10:28 PM
wolfman04's Avatar
wolfman04
Default Help on which catch can to buy.
Getting ready to buy a catch can which one CCA or Elite Engineering?
Old Dec 26, 2007 | 10:56 PM
ZeeOSix's Avatar
ZeeOSix
I've got the Elite CC ... nice unit. Not familiar with the CCA can.
Old Dec 27, 2007 | 02:19 AM
dieseldave56's Avatar
dieseldave56
Default Read before making a choice...............
Read before making a choice:http://www.conceptualpolymer.com/ I run both a coalescing filter and an a catch can (derived from Dave68's concept). I fabricated/ adapted for application from two Binks units. Very satisfied
Old Dec 27, 2007 | 04:10 AM
DeeGee's Avatar
DeeGee
Can't vouch for any of the others
I fitted the EE catch can. As with anything from EE it's an amazing piece of engineering. Nice design, fits easily and does the job. Good price too. I'm very satisfied with mine.
Old Dec 27, 2007 | 05:07 AM
Pumba's Avatar
Pumba
Wolfman,
You may already be aware of this, but if you are not, you need to purchase and install two catch cans. One for the PCV line and the second for the line from the valve cover to the throttle body:
Both lines suck oil, with the valve cover to throttle body line being the biggest offender.
Old Dec 27, 2007 | 09:47 AM
wolfman04's Avatar
wolfman04
Originally Posted by Pumba
Wolfman,
Thanks I have a 04 with the PCV built in does that make a difference?:
Old Dec 27, 2007 | 02:20 PM
ZeeOSix's Avatar
ZeeOSix
I see you also have a filtered breather on the oil filler cap. If you have that, then having a catch can in the fresh air line (valve cover to throttle body) doesn't make much sense as all the fresh air breathing will be through the filler cap breather since it will be the path of least resistance.
Wolfman,
Old Dec 27, 2007 | 03:19 PM
Quicksilver Z06's Avatar
Quicksilver Z06
I have the CCA and am very happy with the product. Also, Chip from CCA was very informative on a number of C5 products and ideas. I agree with the 2 catch can comments, and will be installing another.
Regarding the breather, I was at Homestead road course last month coming through turn 3 & 4 when lots of oil dumped! I put the stock cap back on all is better!
Old Dec 27, 2007 | 03:41 PM
ZeeOSix's Avatar
ZeeOSix
I doesn't make sense to have both a filler cap breather and a 2nd catch can ... it should be one or the other.
You were probably making a high G force LH turn too. Someone needs to make a well baffled filler cap breather so it can separate raw oil from the vapors ... that is what a real breather does.
Old Dec 27, 2007 | 04:10 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Just ditch the TB-to-valvecover inlet line completely if you're going to use a breather filter....what many do with a 90mm TB conversion anyways, since it has no PCV inlet line provision.
I'm also not sure introducing a source of unmetered air on a MAF tuned n/a application is a good idea. (which is exactly what the oil cap breather does anytime there's significant manifold vacuum).
Old Dec 27, 2007 | 04:56 PM
jovette's Avatar
jovette
I purchased and installed the coalesing / Watts style catch can from Dave68's. Works great
Old Dec 27, 2007 | 05:46 PM
Pumba's Avatar
Pumba
That answer would be correct if the don't spend much time on a road course.
But, if you do spend significant time on a road race course, you know that you still pull oil through the valve cover to throttle body hose even with a breather cap. And, that in addition to the two catch cans you need to replace your standard pushrods with Smith Brothers oil flow restricting pushrods to completely eliminate pulling oil into the intake manifold.
Old Dec 27, 2007 | 06:05 PM
SUPERCRUZ's Avatar
SUPERCRUZ
I installed the Elite Engineering unit on mine. I have been nothing but impressed with all EEs products thus far. That said, I think the CCA unit looks like a high quality piece. I do not think you can go wrong with either one. I would go for the one that cost the least. Good luck with it.
Old Dec 27, 2007 | 06:57 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The point being, is WHY do you still have the TB inlet hose at all?
Once you added the oil cap breather, that instantly became your new source of inlet air for the PCV system.
At that point, the TB to valvecover line became completely useless, other than becoming a new potential EXIT point for oil and crankcase vapors under low vac/high rpm conditions, which although it happens stock too, this reversal of flow is even more likely to occur due to the alternate source of inllet air now being present (the oil cap breather).
Instead of trying to prevent ways of oil from entering the intake, you essentially chose to give it two paths. Upon realizing the effects of this, instead of eliminating one unnecessary path, you chose to just filter it.
Also, if you simply drill out the drainholes in your lifter guides, you will find expensive pushrods are not needed to avoid oil backing up in the valve covers.
Instead of restricting the flow of oil TO the parts needing it, why not just increase the drainage capacity of oil away from that area?
Old Dec 27, 2007 | 08:31 PM
VETTING's Avatar
VETTING
Me too...
Old Dec 28, 2007 | 02:06 AM
striper's Avatar
striper
Another vote for the Elite product!
Old Dec 28, 2007 | 08:30 AM
XXXLTRP's Avatar
XXXLTRP
So..the best setup would be 2 catch cans and the stock oil fill cap? I'm a noob and can use all the information ya'll have to share.
To Help on which catch can to buy.
