Gears
Old Dec 27, 2007 | 12:23 PM
yllwvet's Avatar
yllwvet
St. Jude Donor '06
Default Gears
OK, Christmas is over and I hope you all had a merry Christmas and a safe one I have a few extra $ from Christmas and I'm thinking of MODS My A4 with its 2.73 gears seems alwful slow for a vette. I previously put headers, pipes, stal and a different intake system on it. I don't take it to the track just weekends and sometimes to work. What are the pros and cons of changing out to 3.42? How much of a difference will I notice? Any comments or advise is appreciated
Old Dec 27, 2007 | 12:55 PM
csexton's Avatar
csexton
Gary, I had ECS install a 3:42 in my 01 coupe this spring. You will need to have the computer reprogrammed for the new gear ratio. This is my favorite mod to date. The car is much quicker off the line. I lost about 3-4 miles per gallon. You will be very happy with the new gears.
Chuck
Old Dec 27, 2007 | 01:02 PM
lucky131969's Avatar
lucky131969
You are in luck, there is a low miles complete diff in the parts section right now.
Old Dec 27, 2007 | 01:15 PM
vincentjames501's Avatar
vincentjames501
You can't just replace the gears in the diff?
Old Dec 27, 2007 | 01:26 PM
lucky131969
Sure you can, provided you have the correct tools and expertise. Most guys opt for the whole unit. It's easy to swap out. Even though I do all my own work, I would rather buy a complete assembly, with regards to a tranny or differential, than tear it apart myself.
Old Dec 27, 2007 | 02:26 PM
WSPH's Avatar
WSPH
wsph
You will love the difference with the 3.42 gears, My wife gave me Long tube headers, high flow cats, X-pipe and xpipe along with the 3.42 gears, I had it fine tuned , I also had previously done a borla exhaust and vararam . I am getting about 350 hp. to the rear wheel but it really takes off with the 3.42 gears. I can't wait to see what the wife gives me for X-mas next year.
Old Dec 27, 2007 | 02:30 PM
Blow Torch's Avatar
Blow Torch
Go with the GEARS!! If you go ahead and install a stall convertor at the same time, you will not BELIEVE the difference it will make. FOR and AWAY the best mod for an auto!
You will not mind a small drop off in gas milage, since you'll still get excellent mileage for the performance you'll gain.
I personally wouldn't go with the ring gear install. This could be a major headach if it's not done right, and there are some good deals on rear ends on the forum.
Old Dec 27, 2007 | 02:33 PM
94legaleagle's Avatar
94legaleagle
1st, plan on replacing the ENTIRE pumpkin, not simply swapping the gears!!!!!
2nd, do a search, but I'd recommend 3.73 gears AND a Yank SS3200 or SS3600 stall AT THE SAME TIME!!!
Old Dec 27, 2007 | 02:38 PM
hdog's Avatar
hdog
Are 3.90 gears too much?
Old Dec 27, 2007 | 03:07 PM
jordanfd's Avatar
jordanfd
Old Dec 27, 2007 | 03:14 PM
patrickboyle's Avatar
patrickboyle
DO it ! 3.90's & stall converter in my A4. The car is NOT a daily driver. +/- 1000 miles per year. I'd still do 3.90 even if I drove the car more. Buy the rear from DTE & be done with it.
Old Dec 27, 2007 | 04:44 PM
Spiralgrey03's Avatar
Spiralgrey03
Let me join in with the 3.42 choir. Sweet! Your car will be MUCH quicker off the line.
Change the entire pumpkin. Break in the gears with OEM lube then change to synthetic after about 500 miles. Since you would be changing the gears it is a good time to upgrade the torque converter.
Save yourself some money and do it all at the same time. I am very pleased with my Yank SS3200 but I understand the Vigilante 2800 is also a very good set up.
Update to your CUSTOM PCM tune. If you haven't got one already you really should. It is perhaps the best bang for the buck after a CAI.
The combo of gears and torque converter should put a big grin on your face and most others in your rear view mirror.
Good luck.
Old Dec 27, 2007 | 08:26 PM
Bluefire's Avatar
Bluefire
Another vote for the 3:42 gears! I put in a DTE 3:42 and a Yank 2800 stall and WOOOOO-WWHHHOOOOOO!!!. It is a completely different car. You are correct the 2:73 rear end feels anemic. This will completely cure it.
Old Dec 27, 2007 | 10:35 PM
Mike Mercury's Avatar
Mike Mercury
back in the muscle car era;some were so good at doing it - that they could swap rear gears (just the actual gears) in 30 minutes. Back then - if you made a small mistake (and for the discussion... lets say this small mistake caused gear whine to develop) it was just another 30 minutes to correct the small mistake.
The C5's rear transaxle design makes it take a lot of labor hours to just get to where you could replace the internal gears. So; you want it done right the first time... by someone that is a professional at changing gears in this unique Getrag manufactured carrier (diff).
You don't want to be R&R'ing the carrier a couple of times - to correct rookie mistakes in swapping out the internal gears.
Old Dec 27, 2007 | 10:38 PM
Mike Mercury
oh; and here's a primer on rear diff swapping for the C5:
http://mikemercury.home.att.net/342.htm
and here's an inexpsnsive -no external cooler needed- converter upgrade:
http://forums.corvetteforum.com/show....php?t=1715694
To Gears
