Possible cause for bad rings.....hmmmm
Old Nov 26, 2001 | 10:57 PM
chuckster's Avatar
chuckster
Default Possible cause for bad rings.....hmmmm
My C5 mechanic told my he just replaced the rings on a 2001 Z06. He said he thinks the problem is that they use chrome Alloy rings and that they need to be seated properly. His theory is that some folks don't drive the car hard enough in the beginning to seat the rings. Accoding to him these hard rings must be hammered pretty good to seat.
I have regularly driven to redline since my car hit the 1st 500 miles. No abnormal consumption here.
Does this theory hold weight???
Old Nov 27, 2001 | 12:57 AM
ZO6LS6's Avatar
ZO6LS6
Default Re: Possible cause for bad rings.....hmmmm (chuckster)
Chuk, IT used to........still may, from the GM tech bulletin, the # 2 ring is a 9# pressure ring, and at certain RPM's it is "Fluttering", , I take that to mean it's not got enough tensile expansion to keep it in contact with the cylinder walls........
For this reason they went to a ring with 13#'s tensile pressure for the fix, and a different design on the lip........a napier design.....whatever that is.......
Bottom line, the rings do not have enough OUTWARD pressure to keep a proper seal on the piston to cylinder wall ................So, oil is allowed past them, and viola!!!!!!!!!........out the exhaust she goes.
Or, so was the tale from the GM fairies.................. :cry
Old Nov 27, 2001 | 03:25 AM
drive it's Avatar
drive it
Default Re: Possible cause for bad rings.....hmmmm (ZO6LS6)
And supposedly the rings will only flutter with high rpm/low load driving.......
Old Nov 27, 2001 | 10:29 AM
darkmercury's Avatar
darkmercury
Yeah... and only with 6spd C5's!!! So says a Chevy Shop Foreman at one dealership! :rolleyes:
When Auto's have had the same problem too.... I don't have a problem but it burned enough oil during the break in period that I got kinda scared.
Old Nov 27, 2001 | 11:36 AM
Richin Chicago's Avatar
Richin Chicago
I wondered about that. The only connection I can see is a John Napier who invented the logarithm back in the 1500s in Scotland?
Old Nov 27, 2001 | 09:36 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: Possible cause for bad rings.....hmmmm (Richin Chicago)
$$$$$$inChicago...................
Yep, he was multi talented........ :D
Old Nov 27, 2001 | 10:03 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
go to http://www.idavette.net/hib/02ls6/page5.htm for the full story on the rings. :chevy
To Possible cause for bad rings.....hmmmm
