oil change time
Old Dec 29, 2007 | 04:23 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Default oil change time
I'm a new c5 owner, had it for a couple months now, and the DIC is telling me it's time to change the oil (9% remaining). I've searched for a faq or a sticky but couldn't find anything.
I want to do it right and I remember reading somewhere that there is a strange jacking procedure required to get all the old oil out of the pan.
Is there a step-by-step how-to thread on how to change the oil in these cars?
Old Dec 29, 2007 | 04:26 PM
American Hydrocarbon
Guest
Posts: n/a
You could wait until it says 0% if you want to. You need to have the rear slightly higher than the front to get it all out.
Happy New Year!
Pat
Old Dec 29, 2007 | 04:41 PM
SLPRC5's Avatar
SLPRC5
Happy New Year!
Pat
Jack the front up...undo the drain plug, as it drains lower the front and jack up the rear. Let it drain in the position mentioned with the back end up higher than the front for about 10 minutes or longer while you have a beer or coffee. Lower the rear...jack the front..install drain plug...remove filter...install new filter...fill with 7 qts of new oil.
Check for leaks..reset DIC for new "oil life"...
Enjoy
Old Dec 29, 2007 | 04:56 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
Also I don't have any jacking pucks, do I have to get these or are there alternate jacking points underneath the car?
Old Dec 29, 2007 | 05:15 PM
BrianG01's Avatar
BrianG01
Ive used pucks before and didnt like them and have been using plain old jack stands without the fat top peice lately and its been working fine.
Then there is the 6.5 vs 7 quart debate...
Old Jan 4, 2008 | 02:26 PM
Svelte_C5's Avatar
Svelte_C5
St. Jude Donor '09
I was wondering if I could just back the rear end up onto my rhino ramps and maybe jack up the front a little?
Also, is there any special adapter I need to get my torque wrench at the drain plug?
Old Jan 4, 2008 | 03:24 PM
bighank's Avatar
bighank
Default I use Rhine ramps on the FRONT with the car going downhill
And you can make your own pucks with 4 hockeypucks and 4 eyebolts and nuts. Total cost $10 Total value PRICELESS BIGHANK
Old Jan 4, 2008 | 04:23 PM
bmacZO6's Avatar
bmacZO6
I put the front wheels on the rhino ramps than I use the jack straight in from the back with a small piece of plywood under the aluminum sub frame or whatever the heck it is. Look under the back and you will see what I am referring to.
Old Jan 4, 2008 | 07:17 PM
alshirey's Avatar
alshirey
I'm thinking if you back your car on to Rhino ramps, you will have NO room to get the jack under the front end. I have 4 jackstands and a nice low profile jack as my car has been lowered.....ACTUALLY, so low I have made a "mini" ramp from two 2x10's (each side) to get the front end up high enough to get the jack under. Lift and place stands under suspension frame (just inside of A-arms), then go lift the rear and put jack stand at same position...BUT, be sure to have the back HIGHER than the front. Now your car is off the ground, the rest is up to you.
Good Luck.
To oil change time
