Tire Training Trouble
Old Dec 31, 2007 | 12:53 PM
OCDvetteman's Avatar
OCDvetteman
Default Tire Training Trouble
Hey guys, my '99 coupe started showing "left front tire flat" but it wasn't flat. The tire pressure has always read about 3 psi lower than normal. No problems with other TPMs. I did a search and followed the training procedure, and the left front trained, but I cannot get the right front to train. I have a very strong magnet, and I've tried it over and over. Since training the left front it is reading accurate pressure now and no longer hrowing the "flat" code when I drive it. The other pressure readings are blank. Any ideas before I go to the stealership? Thanks guys!
Old Dec 31, 2007 | 02:16 PM
ICUALL's Avatar
ICUALL
Default Try this
When doing the tire re-train try SLOWLY backing the magnet away from the tire/TPS.....
This worked for me..
Old Dec 31, 2007 | 02:55 PM
OCDvetteman
Thanks ICUALL. Tried it very slowly and it didn't work. Also tried something just for the heck of it; after the right front wouldn't train, I stepped back tot the right rear and it trained, then the left rear trained. Tried the left front again and nothing. Thanks for your response!
Old Dec 31, 2007 | 03:22 PM
ICUALL's Avatar
ICUALL
Default Confused
So which sensor is not training ?
As of now your sensors will be reading the wrong tire as each MUST be trained in sequence. Sounds like you have ONLY one bad sensor (right Front).
Old Dec 31, 2007 | 03:36 PM
OCDvetteman
Yep, I'm taking it to the dealer shortly. Thanks!
Old Dec 31, 2007 | 04:35 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
On my high-mileage '99, I had one tire pressure transmitter go bad a couple of years ago. The micro-switch inside decided to stick therefore it wouldn't activate anymore. New transmitter, no more problems.
Old Dec 31, 2007 | 05:00 PM
Corvette Don's Avatar
Corvette Don
I am pretty sure you need a new sensor as that one is prob bad, the others arent far behind, dont go to the dealer they will tell you the same thing I just told you and charge you $70 for it.
Old Dec 31, 2007 | 07:18 PM
OCDvetteman
Thanks guys. All is well, Landers Chevy here in Benton AR took care of me. RF sensor was bad. $170 out the door but I was ready to get r done.
Old Jan 1, 2008 | 01:43 AM
jjvet's Avatar
jjvet
OUCH no lube
Old Jan 1, 2008 | 02:47 AM
DeeGee's Avatar
DeeGee
For future reference the TPS for a 99 is $86 from a Forum Vendor (more expensive than the later model C5s) and a tire shop would change it for a few $$.
As your sensors are starting to go bad the others may follow (the battery life is about7 years or so). You may want to buy online and have the rest done at a tire shop once they start to fail. You'll save a few $$.
Old Jan 1, 2008 | 11:25 AM
Corvette Don
And I could of got you one cheaper than that, but glad you got it taken care of
Old Jan 1, 2008 | 02:54 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Ouch, That had to hurt, It sounds like your battery in the sensor went bad.
To Tire Training Trouble
