AFR Goes Lean .... Sometimes.
Old Dec 31, 2007 | 10:26 PM
Dirty Howie's Avatar
Dirty Howie
Default AFR Goes Lean .... Sometimes.
I need some help.....
During the last ten days my car is running perfect AFR one day and the next it is extreamly lean. The tune is not being changed. I have a WB. When it is lean (over 14.0 it is pinging) so I believe the WB is accurate and something is allowing air in .... but not every day. I have cleaned the MAF and turned the airpump off. I also put the car in SD to confirm its not the MAF signal.
Would someone like to offer some possibilities and how to check for them.
Thanks,
DH
Old Jan 1, 2008 | 10:44 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks,
DH
Do you have a vaccum gauge installed ? What is it reading when the AFR goes wacky ?
Old Jan 1, 2008 | 12:30 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check your O2 sensor output readings. See if they look normal when the problem occurs.
Some other things that can effect A/F ratio are:
Intake Air Temp sensor
Map sensor
Coolant temp sensor
Use a scaner and watch all of those values to see it one is providing erratic readings or going open or shorted.
I have EFI Live and can make a PID file to monitor what ever sensors that I choose. See if you can find someone with EFI Live, HP Tuners ect and maybe that can help you figure it out.
BC
Old Jan 1, 2008 | 12:38 PM
Gonzo's Avatar
Gonzo
OK, this is a really dumb question, but where are you getting your AFR number from ????
I know that if it is not being read correctly, you will get incorrect results. This happened to me when I was having my Z dynotuned. Long story short, my guess is to first verify the AFR reading are correct and that is indeed what is causing the pinging.
Disclaimer: all I know about cars is what I learned on CF, from other guys like me
Old Jan 1, 2008 | 04:33 PM
Dirty Howie
No vacuum guage.
AFR goes to high 13's to 14's when commanded is 12.8
DH
Old Jan 1, 2008 | 04:37 PM
Dirty Howie
Map sensor
Coolant temp sensor
BC
My coolant is reading normal
My IAT seems to be reading ambient temps as usual
I have HPTuner and I can look at all these parameters. So I will try to see if one looks odd. I'm just not good enough to maybe tell.
I am going to block off the end of my A.I.R system. If the check valve in there is getting stuck this will be easy to remove from the possible list.
Thanks,
DH
Old Jan 1, 2008 | 07:57 PM
HP_Addict's Avatar
HP_Addict
I had a similar problem. One bank would go lean occasionaly. I checked everything, I was ready to pull my hair out, then I replaced the O2 sensor. That fixed my problem. So check your O2s.
Old Jan 1, 2008 | 09:06 PM
petercln's Avatar
petercln
Could the fuel pump be getting weak or an injector getting cloged cause the problem?
Old Jan 2, 2008 | 12:36 AM
Dirty Howie
I am currently running in open loop so it has nothing to do with 02 sensors.
DH
Old Jan 2, 2008 | 12:38 AM
Dirty Howie
Hi Peter
Anything is possible...good thoughts
The injectors are brand new.
The fuel pump is a little older.......109K mile
But it has not been a gradual problem. AFR was dead on one day and then extreamly lean the very next.
DH
To AFR Goes Lean .... Sometimes.
