shocks for drag racing
Old Jan 2, 2008 | 09:56 AM
nickolbag's Avatar
nickolbag
Default shocks for drag racing
Got about 63k on the stock shocks and think its time for new ones. The c6z shocks are the cheapest and was thinking of going that way but am wondering what I can gain on the track with adjustable shocks or any other kind of aftermarket shock. Im sure the c6z shocks will perform well. I just dont know if adjustable shocks will outperform the c6z's enough to offset the additional cost. Anybody got any numbers on the track to compare stock, c6z's, aftermarkets?
Old Jan 2, 2008 | 12:19 PM
123sugey's Avatar
123sugey
Dig
I used lakewood 90/10 drag shocks part # 40101 with 2-1/2 " extentions. Remove or undo front sway bar.
NO Corvette tax !!
Someone did a write up on it about a year ago (on this forum) after i told him what to do.
Old Jan 2, 2008 | 12:33 PM
lucky131969's Avatar
lucky131969
NO Corvette tax !!
So I take it you are not plowing through the twisties any more with that setup......
Old Jan 2, 2008 | 12:46 PM
vsocks1's Avatar
vsocks1
Was curious about a good street shock that would be good for drag racing also. I bought some HAL QA1 adjustables, thinking that was a good solution. Have not installed yet and my car is put away for the winter! Any info on this topic I would also be interested in hearing.
Old Jan 2, 2008 | 01:28 PM
nickolbag's Avatar
nickolbag
NO Corvette tax !!
How do those feel on the street?
I remove my front sway bar for track days. Was cutting 1.50-1.51 60's all day with my stock shocks and no sway bar. I think I should have been 1.49-1.50(was slightly bogging) if I were coming out perfect. I would think I could at least match that with c6z shocks(maybe improve???) but was also curious as to what improvements I cna see with adjustables or a drag shock.
Old Jan 2, 2008 | 02:34 PM
123sugey's Avatar
123sugey
Dig
I'm into straight line performance.
I was having major traction issues for years and forgot that i used the Lakewoods and extentions on my street strip C4, 5 years ago.
Well, i got a 1.40 60 ft with my old setup (C5)... my previous best with my C5 was a 1.78
The front lifts now allot quicker and planes out in beginning of 3rd gear ( A4).
Works for me and others on this forum that tried it.
Old Jan 2, 2008 | 02:53 PM
big hoss 98C5's Avatar
big hoss 98C5
So what rear shocks are you running for that 146 60' and hows it feel on the street?
Old Jan 2, 2008 | 03:13 PM
nickolbag's Avatar
nickolbag
Well I have no problem lifting the front as I routinly pull the front wheels off the ground on stock suspension. I do not have that much of an understanding on drag shocks. Are they designed to let you come up fast and come down slower and smooth?
I know 1.40s have been done on stock c5z suspension before with around 475 rwhp. I've gone 1.50s with stock c5 suspension and think a 1.49 is possible with 420 rwhp.
Old Jan 2, 2008 | 04:14 PM
123sugey's Avatar
123sugey
Dig
You want the rear tires to plant.. so the front drag shocks let the front come up allot quicker for weight transfer and come down smoothly. I use stock shocks in the rear.
If you don not have a traction issue, keep the stock shocks.
I was using a 225 shot with 3:90 gears and 5000 stall converter. So the drag shocks helped me.
Old Jan 2, 2008 | 04:18 PM
123sugey's Avatar
123sugey
Dig
The drag shocks and no sway bar are fine on the street for me. Obviously cornering is greatly affected. With regular driving around corners, you wont have a problem.
Old Jan 2, 2008 | 04:22 PM
big hoss 98C5
Hows the ride feel with the bar in on the street?
Old Jan 4, 2008 | 05:40 PM
INTHERED's Avatar
INTHERED
What is the theory behind removing the sway bar at the track ?
Old Jan 4, 2008 | 06:12 PM
nickolbag's Avatar
nickolbag
The theory is that it helps the front suspension unload more efficiently. I've heard it helps but also that it helps more for F-bodies than for Vettes. Also the obvious that it takes some weight off the front end. I only have two days to compare times to, one with the bar and one without the bar. With the bar my 60's were consistantly 1.54-1.55 and without the bar they were 1.50-1.51. Given that these were 2 different days and done with a driver just learning to drag race it is hardely a reliable observation.
Maybe somebody else has more input on how much it helps?
Old Jan 4, 2008 | 06:32 PM
INTHERED's Avatar
INTHERED
Old Jan 4, 2008 | 07:17 PM
pit-man's Avatar
pit-man
Default sixty foot
Your pretty right on Nickol..I just cut a 1.489 on 433 rwhp. That was swaybar on and stock suspension & shocks.
Pit
Old Jan 6, 2008 | 08:51 PM
12leavu's Avatar
12leavu
NO Corvette tax !!
are the 2.5 extentsions nessecary? i assume they are. my car is lowered will that make a difference on extention length? how much are the extentions?
Old Jan 6, 2008 | 11:57 PM
396375's Avatar
396375
St. Jude Donor '08-'09
I would go with the QA1s on the rear of any Vette with sticky tires and good power.It seems the rear end is unforgiving to any wheel hop,and usually breaks first time.Just good insurance.
Take care.
To shocks for drag racing
Old Jan 7, 2008 | 11:41 AM
HP_Addict's Avatar
HP_Addict
Who sells the Lakewood shock? Did I read it correctly that you are running these in the front only and stock shocks in the rear? The QA1s are awesome, but expensive.
Old Jan 7, 2008 | 02:50 PM
12leavu's Avatar
12leavu
summit sell them. im still waiting for someone to reply about the extentions.
Old Jan 7, 2008 | 03:08 PM
12leavu's Avatar
12leavu
called summit they have 3 inch extentions. they are for 3/8 studs. but they didn't know the stud size for the lakewoods, so do any of you guys know?
