another cam question help
Old Jan 2, 2008 | 11:57 AM
03redzo6's Avatar
03redzo6
Default another cam question help
ok i got a 2003 z06 with a halltech intake, high flow cats, wcc x-pipe, and b&b bullets. my car is also a daily driver so it can't be to wild and it has to be reliable. i really want a cam that will pass cal. smog and will give me good power from idle all the way to redline, i have a couple of choices that i think might be pretty good but they say it will not pass smog i have to go with a smaller cam. btw my goal is to be able to get 450+ rwhp with ported heads, fast 90mm intake man, and 90mm thottle body later on in the year. any members ever delt with these cams before or have them. thanks, albert.
mti g1 228 232 113
mti x1 230 227 112
mti r1 232 236 114
recommended cam is the mti c2 224 224 112
Old Jan 2, 2008 | 12:01 PM
02gt350's Avatar
02gt350
i have a 224/224 112+4 and love it...BUT, i would have liked ot go a bit bigger
Old Jan 2, 2008 | 12:03 PM
lucky131969's Avatar
lucky131969
mti g1 228 232 113
mti x1 230 227 112
mti r1 232 236 114
Why not just bolt on a SC and be done with it? You'll have horsepower on tap, and don't have to crack the motor open.
Old Jan 2, 2008 | 12:15 PM
03redzo6's Avatar
03redzo6
by any chance do you have a video of your car with the cam.
the reason i dont wan't to go with a sc is because i started to road race my car and there are a couple of forums members that have had heating issues with there car.
Old Jan 2, 2008 | 08:40 PM
spiral04's Avatar
spiral04
In California our smog laws suck. If the smog tester is an A-hole, the sound of the cam can actually cause them to fail you(visual failed inspection). I believe the largest cam I have heard to pass would be a 224/228 114. Larger cammed cars can have some tuning taken out for the test though. Call and talked to local forum tuners who have done them. They'll point you in the right direction. Check my sig for mods and numbers.
Old Jan 2, 2008 | 09:24 PM
stormrider's Avatar
stormrider
You might want to consider ECS's blower cam. Yellow03Z06 got some pretty amazing numbers out of that cam and he lives in CA.
http://forums.corvetteforum.com/show...&highlight=cam
Old Jan 3, 2008 | 09:20 AM
02gt350's Avatar
02gt350
this was with cutouts open though...much more rowdy that just through the catback
Old Jan 3, 2008 | 11:10 PM
03redzo6's Avatar
03redzo6
that sounds awsome, i really wan't something like that
To another cam question help
