2 piece front cover question (s)
Old Jan 3, 2008 | 09:29 AM
LDB C5's Avatar
LDB C5
Default 2 piece front cover question (s)
I am in the process of a head cam swap and decided to go with a 2 piece front cover. If I decide to change cams (or return to stock) in the future, I wont have to drop the steering rack or remove the balencer. I have a couple of questions:
What gasket did you use?
In looking at how it's manufactured, I dont see a big leak potential where the split is. How are you guys sealinig this area? hi temp RTV?
Thanks!
Old Jan 3, 2008 | 10:48 AM
lucky131969's Avatar
lucky131969
Thanks!
No instructions with the kit?
Old Jan 3, 2008 | 10:49 AM
LDB C5's Avatar
LDB C5
Nope, none.
Old Jan 3, 2008 | 10:57 AM
lucky131969
Nope, none.
That's lame....what type is it?
Old Jan 3, 2008 | 11:06 AM
LDB C5's Avatar
LDB C5
Summit Racing is where i bought it
Old Jan 3, 2008 | 11:18 AM
lucky131969
I just talked to a buddy who installed one last year. His is a QTP, which I think is the same one at Summit. He said, after the bottom piece is installed, apply high temp silicone to the lip of the top piece and mate together.
Old Jan 3, 2008 | 11:22 AM
vettenuts's Avatar
vettenuts
I would be curious as to how well you can see the timing marks with the lower half in place.
Old Jan 3, 2008 | 11:29 AM
LDB C5's Avatar
LDB C5
I'm pretty sure that it will be a bit more difficult to see the mark on the crank gear; but if you think about it, as long as the new cam goes in the same way the old one came out, you really don't need to see the crank gear. You could spend 2 hours aligning the cam gear correctly and still be time ahead of dropping the steering and pulling the balencer.
Old Jan 4, 2008 | 10:03 AM
Quick Time's Avatar
Quick Time
If ya need instructions regarding our timing cover just email us sales@quicktimeperformance.com
Old Jan 4, 2008 | 10:52 AM
LDB C5's Avatar
LDB C5
Thanks Barry
To 2 piece front cover question (s)
