A/C Sensor Part Number?
Old Jan 4, 2008 | 01:50 AM
RrCoX22's Avatar
RrCoX22
Default A/C Sensor Part Number?
What is the part number for this sensor coming out of the further passenger side of the A/C compressor, right behind the belt tensioner. Looks like it's connected to the wiring in the second pic...
Old Jan 4, 2008 | 10:43 PM
RrCoX22's Avatar
RrCoX22
bump... anyone know the part number for that sensor???
Old Jan 4, 2008 | 11:20 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its NOT a sensor, its the connection to the AC Compressor Clutch. The only way to replace the connector on the compressor is to replace the clutch electromagnet assembly and that requires removal of the pulley.
Looks like your lucky and only the female plug on the end of the harness is damaged. Get a new plug end from Gene Culley at GMPARTSHOUSE.COM. That will be the least cost. Then you can splice it on to the wires or solder the wires to the pins inside the connector. You can extract them if you release the small tab that secures them in the plastic connector body. That female connector will come off the male compressor connector!
Hope that helps. How did it get broken??
BC
Old Jan 5, 2008 | 12:05 AM
RrCoX22's Avatar
RrCoX22
BC
ok what is the part number for the female plug? ...does the plug come with wiring attached?
...it was actually like that when I bought the car
Old Jan 5, 2008 | 11:57 PM
RrCoX22's Avatar
RrCoX22
bill i searched... and couldn't find it
anyone know where i can find the part number for that plug???
Old Jan 13, 2008 | 03:15 PM
RrCoX22's Avatar
RrCoX22
bump???? anyone???
Old Jan 14, 2008 | 06:27 AM
RrCoX22's Avatar
RrCoX22
up top...
Old Jan 14, 2008 | 10:48 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
As Bill said, contact Gene Culley at GMpartsdirect.com, he is great with looking up numbers for these sorts of parts.
Old Jan 14, 2008 | 02:47 PM
RrCoX22's Avatar
RrCoX22
lol... i thought i did but it actually went to Bill Curlee
...so Gene can you help me out?
Old Jan 14, 2008 | 02:58 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Yep, 610.862.0550, and ask for Gene Culley
Old Jan 14, 2008 | 03:07 PM
lucky131969's Avatar
lucky131969
bump???? anyone???
Have you tried calling your local dealership?
Old Jan 14, 2008 | 07:50 PM
RrCoX22's Avatar
RrCoX22
my local dealership parts dept. has a bunch of airheads
Old Jan 14, 2008 | 07:52 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check out this post for some more sources of connectors!
http://forums.corvetteforum.com/show....php?t=1913073
BC
To A/C Sensor Part Number?
