About to change cams on my 02 C5.I have a ? about the power steering pump.Do you have to remove the pump to change cams?
I have been gathering parts and need to know if I need a new pulley for the pump.
If your just changing the cam the P/S pump/pully are NOT removed on a C5. The P/S lines on the rack have to be removed and if you have a cooler the return line will be removed off the pump but the pump itself stays put.
Thanks RonSS,I am only do the cam.Thats the info I was looking for!
