skip shift bypass resistor
Old Nov 27, 2001 | 10:59 PM
Pizzazz's Avatar
Pizzazz
Default skip shift bypass resistor
Any one know what value the bypass resistor is?
Old Nov 27, 2001 | 11:21 PM
1SGRET's Avatar
1SGRET
St. Jude Donor '12-'13
Default Re: skip shift bypass resistor (Pizzazz)
2.2K. About a buck at Radio Shack.
Old Nov 27, 2001 | 11:24 PM
JohnGlenn's Avatar
JohnGlenn
It's 2200 ohm (2.2K ohm) 1/2 watt.
Check out this page for how to:
http://www.ls1.com/link_cags.html
That's how I did it.
Good Luck
Old Nov 27, 2001 | 11:26 PM
JohnGlenn's Avatar
JohnGlenn
Default Re: skip shift bypass resistor (99hrdtop)
Looks like I was a little too slow with my typing.
99hrdtop beat me to it.
:D :D
[Modified by JohnGlenn, 9:27 PM 11/27/2001]
Old Nov 27, 2001 | 11:47 PM
andy_t's Avatar
andy_t
The LS1 website has great instructions. I also used some rubber plugs that I picked up at Ace hardware to cover the connectors. The fit right over the OEM plugs. Then I used a minimal abmount of tape around them to finish them off. In all, about $3.00 for the mod.
andy t.
Old Nov 28, 2001 | 12:28 AM
Corey_68's Avatar
Corey_68
Default Re: skip shift bypass resistor (andy_t)
Did you get any error codes or skip shift lite still come on afterwards?
Old Nov 28, 2001 | 05:17 AM
Richin Chicago's Avatar
Richin Chicago
Default Re: skip shift bypass resistor (Thad)
A long as the resistor is there and the CPU sees it you shouldn't get any error codes. The CPU can't tell the resistor from the solenoid. And yes the skip shift light still comes on but is meaningless.
Old Nov 28, 2001 | 07:56 AM
Av8ter's Avatar
Av8ter
Default Re: skip shift bypass resistor (Richin Chicago)
The resistor works great. That skip shift crap was driving me crazy. Just turn the ignition off, jack up the rear driver side of the car, put jackstand in place, crawl under and install the resistor. Also when you insert the resistor in to the wire harness plug, dont insert it where the normal prongs from the plug would go, insert the resistor ends on the other side of the metal pins. I found that if you insert it where the prongs go that the connections just werent all that tight and over time I didnt want it to lose connection and cause a code. When you pull it apart you will see what Im talking about. Anyway, after installing the resistor, I bent it over the plug and used a small tie-wrap to permenantly secure it and then wrapped it and the plug on the transmission with electrical tape to prevent dirt and water from getting inside. Then secure the wire harness to something with another tie-wrap to keep it from dangling.
Old Nov 28, 2001 | 08:12 AM
Bluvette1's Avatar
Bluvette1
The 2.2k is all you need it works great, no codes!
To skip shift bypass resistor
