Efficient mod-install priority? Quick sanity check!
Old Jan 5, 2008 | 07:22 PM
TXCatalyst's Avatar
TXCatalyst
Default Efficient mod-install priority? Quick sanity check!
Hey everyone - need a quick sanity check to see what order I should be installing the followings mods so that it makes things easier (ie. more header clearance?) and or... so I don't repeat the same labor/task over and over again:
So here are the mods to be installed (all sitting in the dining room) in no particular order:
1. Longtube headers (full exhaust)
2. LS6 intake manifold with the correct coolant adapters/plugs
3. Spark plugs
4. Plug wires
5. Blackwing Intake - complete (SLP smooth bellow and coupler)
6. PCV valve
7. Fuel filter
Any other 75k mile maintenance items I should "well, while you're in there, you might as well do this...." type things?? Yea, I'm all about the efficiency.
I appreciate all feedback!! Thanks in advance!
Old Jan 5, 2008 | 07:30 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Do:
1.Fuel Filter
2.PCV Valve
3. LS6 Manifold
4.BlackWing Intake
5.Headers (Have to remove the plugs and wires anyway)
5.Plugs and wires
Thanks,Matt
Old Jan 5, 2008 | 11:57 PM
jpandes's Avatar
jpandes
What about swapping in a 160 degree thermostat while you are in there and get fans set to turn on earlier when you get it tuned.
To Efficient mod-install priority? Quick sanity check!
