LS1 Edit, is it out yet?
Once it is ... there will be a post... :D
I guess SteveCole is also working on a similar program... will be a good comparison.. hopefully it won't be limited in anyway once it locks to your car. ;)
BTW, the locking is for your own good. :p: :rolleyes:
[Modified by SlowC5, 3:04 AM 11/28/2001]
[Modified by SlowC5, 3:05 AM 11/28/2001]
They are still working on the manuals before releasing the individual version.
He also said the 1997/1998/2001 were quite a bit different meaning more time.
The 1998 should be ready by winter and then the 2001.
I am excited since i have a Y2k Corvette and a 1999 GMC 5.3L LS1 truck, which means i can use the same program for both.
Michael
[Modified by Austrian Vette, 5:19 PM 11/28/2001]
550 Bucks for consumer version due out anytime (not all year C5's tho yet).
Based on what you know, I have a few questions for you:
Do you figure there are any pitfalls to do it yourself programming with a product like this?
Can the average C5 owner be able to tweak properly without hurting anything?
Can the average C5 Owner expect to learn from guys like you and others who delve deeply in this stuff over a board like this in a manner that will be as easy as it seems?
Is diagnostic software like auto tap still necessary?
Thanks,
RG
Yes, someone can screw up thier timing and fuel tables, but as with most things its trial and error. Can someone hurt thier motor? Yes if they load a bad program and go out and banzai down the track or street. But it will be a baby step processs. Load, drive easy, scan, see whats going on, then step it up. LT1Edit thats been around for a while has lots of help out there for it.
You will pull down your current program, save it, and load up your edited program.
Here is an example of the LT1 features. LS1 edit features will be similar:
As always I will contribute any help I can as I ramp up to using it.
(from carputings site about thier current LT1 editor)
The Standard LT1 editor includes editing the following items:
Idle speed by temperature in Gear
Idle speed by temperature in Neutral & Park
Adjustment for Rear End ratio change and Tire size change.
Fan On temperature, First Stage Under MPH Speed threshold
Fan On temperature, First Stage Over MPH Speed threshold
Fan On temperature, Second Stage Under MPH Speed threshold
Fan On temperature, Second Stage Over MPH Speed threshold
MPH threshold for Fan threshold
Fan hysteresis temperature
Fuel Cutoff in MPH
Fuel cutoff in RPM while in First Gear
Fuel cutoff in RPM while in higher gears
Fuel Resume in MPH
Fuel Resume in RPM while in First Gear
Fuel Resume in RPM while in higher gears
For the A4 Trans:
Normal Mode Shift Speed in MPH vs Throttle Position for 1-2, 2-3, & 3-4 upshift
Normal Mode Shift Speed in MPH vs Throttle Position for 4-3, 3-2, & 2-1 downshift
Performance Mode Shift Speed in MPH vs Throttle Position for 1-2, 2-3, & 3-4 upshift
Performance Mode Shift Speed in MPH vs Throttle Position for 4-3, 3-2, & 2-1 downshift
Manual Mode Shift Speed in MPH vs Throttle Position for 1-2, 2-3, & 3-4 upshift
Manual Mode Shift Speed in MPH vs Throttle Position for 4-3, 3-2, & 2-1 downshift
Shift Pressure vs Temperature vs Throttle positio
Wide Open Throttle Shift Points in MPH
Normal Mode shift points in MPH while in Kickdown Mode
For the M6 Trans
CAGS(SKip Shift) Engage and disengage Speed in MP
CAGS Engage and Disengage Load in kp
CAGS Enable temperatur
CAGS Disable RP
CAGS % throttle to Disengage
The expert version adds:
These Fuel Tables
Open Loop AFR vs. Load vs. Temp
%TPS for WOT vs. RPM
Power enrichment vs. Temp
Power Enrichment vs. RPM
Volumetric Efficiency 0 to 7000 RPM vs. %TPS
MAF Calibration Frequency vs. Air Flow
Inlet Air Temperature Scaling
Cylinder size
Injector size
and these Ignition tables
Load vs. Advance vs. RPM
Load vs. Temp vs. Advance
Temp vs. Advance
Closed Throttle Spark Advance
Minimum Spark Advance
Maximum Knock Retard vs. RPM
Maximum Knock Retard vs. MAP
Knock Retard Attack Rate vs RPM
Knock Retard Decay Rate vs RPM
Knock Retard Minimum Coolant Temperature
Burst Knock Enable Temperature
Low Octane knock retard
Knock Count to enable Retard
and additional transmission parameters
TCC Apply vs. %TPS vs. MPH
TCC Release vs. %TPS vs. MPH
Line Pressure vs %Throttle vs MPH
Kick Down Mode Hot up and downshift in MPH
Hot shift vs. RPM
as well as the ability to disable or enable: VATS, traction control, and speed Density Mode. and verify the AIR hardware.
[Modified by kewlbrz, 12:45 PM 11/29/2001]
As always when you flash the PCM there is a danger or corrupting the PCM during that process. Besides that risk incorrectly programming the PCM could result in serious harm done to your car/engine.
[Modified by Godspeed, 12:50 PM 11/29/2001]
Remember when messing with the PCM, that you always start off easy with a scan tool after flashing and make sure your parameters are looking good, and ramp up easy to WOT runs etc.
