interior light problem?
Old Nov 28, 2001 | 02:29 PM
Blacked-out's Avatar
Blacked-out
Default interior light problem?
I bought a c5 that was wrecked, cleared all the error codes and the DIC says door is open....I checked all are closed so I pulled the fuse for now.
Anyone have any suggestions???
Old Nov 28, 2001 | 04:22 PM
RadarBlue's Avatar
RadarBlue
Default Re: interior light problem? (black_c-5)
Did you get any more error codes after you cleared them? If so, what are they?
Old Nov 28, 2001 | 04:31 PM
Blacked-out
The only thing the DIC says is door adjar......no error codes.......freaky..eh?
Old Nov 28, 2001 | 05:04 PM
RadarBlue's Avatar
RadarBlue
One thing that you can do is to check the connections to the door control modules, otherwise it's going to take a scan tool and a service manual to track this down. Possibilities include bad right or left Door Control Module (DCM), right or left door latch, Instrument Panel Cluster (IPC) as well as a broken wire. You said the car has been wrecked, where and how extensive was the damage?
Old Nov 29, 2001 | 08:46 AM
Blacked-out
Default Re: interior light problem? (RadarBlue)
I checked them and they are alright......would'nt the Body control module pick up if there was a bad connection???
Do you know where the "switch" is located that tells the car the door is closed?
To interior light problem?
