IAT sensor relocation on a 99?
Old Jan 9, 2008 | 09:38 AM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Default IAT sensor relocation on a 99?
I am putting a C6 vararam on my car and moving my MAF back to right in front of the 90mm throttle body but the problem is that there is no room for the IAT sensor between the MAF and throttle body. Any suggestions? Can I put the IAT in front of the MAF?
Cajun
Old Jan 9, 2008 | 09:44 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Depends on what part of the country you are from. You could always leave it disconnected and do the timing trick mod.
It involves adding a resistor into the plug and not hooking it back into the sensor.
It tricks the computer into thinking it is always a certain temp outside. So a search, someone posted a chart awhile back that showed what resistor made it a certain temp.
Old Jan 9, 2008 | 10:11 AM
WKMCD's Avatar
WKMCD
I don't see why it wouldn't work in front of the MAF. The aire temp is not going to be any different.
Old Jan 9, 2008 | 10:15 AM
0Cajun @ Edgyvette
Former Vendor
I agree, but just want to make sure. I guess if it doesnt start or acts crazy then I know huh. LOL
Cajun
Old Jan 9, 2008 | 10:35 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Cajun
You could alway do this mod.
http://ls1howto.com/index.php?article=25
Old Jan 9, 2008 | 10:43 AM
0Cajun @ Edgyvette
Former Vendor
No longer an issue. The C6 VR does not fit under the hood without takin the radiator shroud cover off. Not installing and listing for sale now. Oh well
To IAT sensor relocation on a 99?
