Which Cam????
Headers are definitely going to help your project, you'll definietly need them with a cam to get the most out of it and the tune. Is your car an Auto or Manual? If it's an Auto, are you planning on a converter? That's going to determine the size of the cam you can go with. Good all around cams are the 224/224 .588/.588 or 228/228 .595/.595 cams. Personally I like the LG Motorsports G5x3 cam, but some would consider that a "big" cam. I consider it on the larger side of streetable. The F13 is a good cam as well, that I've seen good results with that would be inbetween the 228/228 and the G5x3 cam. It's really a question of what you want, there's as many opinions about cams as there are cams out there.
Automatics you can expect between 400rwhp and 440rwhp on our same dyno, once again depending on the cam size.
If you're expecting to make more than 420rwhp on our dyno (440rwhp on a dynojet), I would suggest 1 7/8" x 3" headers.
I did mine about 4 years ago so was worried about driveability. Now they can tune the bigger cams to be more streetable. If you have a MN6, I would not go below a 228.
Definately get the headers first. They made a huge difference by themselves.
are these heads cut? 62cc?
What head gasket 0.053 or 0.040?
I like to use a DCR calculation to pick cams.
I like the added exhaust duration with ls6 heads.
a 3200 stall with the auto is recommended.
a 3.42 gear in an auto or a 3.90 gear in a stick helps the package.
some KOOK or LGM headers
I like spending your money
Cams are commonly referred to as a "size" by it's duration values. Of course there are many other factors and specs to consider, but duration is the one spec that will quickly tell you what a cam is all about.
In general, low duration = docile manners with a low rpm range.
High duration = high rpm powerband, rough idle, worse manners, etc.
The typical scale of aftermarket cam durations (@.050, which is what most now advertise) goes like this:
210-220 - Baby cam, slight power increase, car will run and drive like stock. Emissions and mileage virtually unaffected.
220-230 - Small cam, car will still behave very well, but enjoy more power throughout the stock powerband (2000-6200rpm). Might be a hint of idle roughness, but easily drivable and docile mannered enough for most anyone. Might still pass emissions if in the low.mid 220s.
230-240 - Moderate cam, loud, rougher idle, lope becomes quite noticible (definitely won't be mistaken for stock), powerband will usually extend to 6500 or higher. Doubtful to pass any emissions sniff test, and mileage probably goes down some. Also at this point, higher ratio gears, and.or higher stall tq converter becomes recommended.
240 and up - Big cam. Very loud, very rough idle, makes big power to 7000+ rpms, generally poor manners at low rpm operation (<2000rpms). Tuning can make these sorts of cams streetable, But they are still not for the faint of heart. Gears and/or high stall tq converter highly recommended.
The 02+ Z06 cam in comparison is a 204/218. You can see where that fits in above.
Again, there is MUCH more to cams than this....just giving you a quick newbie guide as to what people refer to as a big cam, small cam, etc.
Your best bet is to find a local tuner that can help you achieve your goals, not everyone wants the same thing, and cam choice is always a compromise. Generally, the bigger you go, the more peak hp you can expect...but you will need to decide at what point the negatives outweigh the gains.
Here they are:
http://www.texas-speed.com/shop/item...d=167&catid=44
or
http://www.texas-speed.com/shop/item...d=669&catid=44
or as a heads cam package with PRC LS6 heads!:
http://www.texas-speed.com/shop/item...d=680&catid=47
Good Luck
Jason
Texas Speed
www.texas-speed.com
with mods in sig i hit 450 through 4:10's. i still have driveability issues though. stalling in parking lots, at stop lights. its very fustrating. its been to my tuner many, many, many times. we cant seem to figure it out. my car is a curse to tune. i think its un tunable
But do both you'll feel and hear a big difference.
