I have a question for you. I am getting ready to install new headers on my 97 Some people say I can reuse the factory gasket and header bolts. Since my system does not come with these new components, I deceided to get new gaskets anyway..I figured it was cheap insurance for $20. But the header bolts will run roughly $100 for the ls1 ARP ones. Will 10 years of heat cycles on the factory bolts and the new flange thickness Vs factory manifolds be an issue ?
Just looking for input before I spend our hard earned $$.
I went with the ARP studs so I could hang the gasket and then the header since I was working alone. ARP is quality stuff. It also helps eliminate cross-threading which can easily happen trying to hold the header up and the gasket and then get a bolt in. They are not necessary, but they are a nice addition.
OEM gaskets are excellent quality. I just had headers installed on my 97 using stock gaskters and bolts. No problems with leaking yet....but then again it's only been a couple of weeks.
thanks in advance.
CD
You'll be fine with the set of new OEM header gaskets. I went with the Stage 8 locking header bolts for my LG Street's but the ARP are as good or better. I probably would not reuse the stock header bolt hardware since you'll be removing it anyway.
You can reuse the stock bolts if they are in good condition. I have the stock bolts and have had my headers on and off quite a few times. I would suggest using a split 8mm lockwasherbetween thebolt head and the header flange to ensure they stay tight and also to keep the bolts from bottoming. Make sure you use some anti-sieze on the bolt too.
One other point, my stock gaskets (02) had oval ports and would not have sealed the headers correctly. I used the round port (Camaro) gaskets. Not being familiar with the 97 exhaust gasket just wanted to point this out.
Stage 8 locking header bolts here about $40.00
Reason: additional info
