XR-1 Owners
Old Nov 28, 2001 | 04:52 PM
C5SilverBullet's Avatar
C5SilverBullet
CI 4, 5 & 9 Veteran
St. Jude Donor '08-'09-'10
Default XR-1 Owners
I just got mine from FedEx today and I am going to intall them tomorrow. Is there any pipes that run from the resonator to the headers or does it fit right up to the headers?? Thanks
Old Nov 28, 2001 | 05:34 PM
thekev_2000's Avatar
thekev_2000
Default Re: XR-1 Owners (C5SilverBullet)
Mine hook up to the pipes behind my cats....if you have your cats removed then you would need an extra pipe to connect them
Old Nov 28, 2001 | 06:40 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: XR-1 Owners (thekev_2000)
^^^ :yesnod:
Old Nov 28, 2001 | 10:10 PM
geekracer's Avatar
geekracer
See http://www.corvetteforum.net/c5/mmarquez/borlaview.jpg for a picture of mine with the stock pipes. You have to cut the existing pipes behind the O2 sensors and slip the front of the resonator over the cut part. I did my own and you need to measure and trial fit to get it right. I also had it welded instead of using clamps.
If your doing a new install with headers you will need new material unless you cannibalize your old pipes. In this case I would mount the resonator from the spring loaded bracket and measure (trial fit) from the front to the header collector (or rear of cats & O2 sensors). Make sure to allow for the slip joint!
Good move with the XR-1 :cheers:
[Modified by MMarquez, 8:12 PM 11/28/2001]
Old Nov 28, 2001 | 10:26 PM
jpvette's Avatar
jpvette
Good luck hearing your stereo system. I love my sound system and I love my XR-1. You just can't love them at the same time. :crazy:
Old Nov 28, 2001 | 10:37 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI IV Bracket Champ
Default Re: XR-1 Owners (jpvette)
I haven't listened to the radio since I installed my Borlas....love the sound of 'em too much :D
Old Nov 28, 2001 | 11:24 PM
Vette-Racer's Avatar
Vette-Racer
MMarquez has good detail on the job, the only thing I can add is that my passenger rear bracket made the pipe hang lower when bolted up so I shimmed it with some washers.
You need to hear these pipes on TPIS :crazy: :smash: :smash:
Old Nov 29, 2001 | 08:38 AM
thekev_2000
Default Re: XR-1 Owners (Vette-Racer)
[QUOTE]You need to hear these pipes on TPIS :crazy: :smash: :smash:/QUOTE]
Vette-Racer is correct, XR-1s on any long tube header..... :crazy: :crazy: Mine are the DRM/TTS and WOW
To XR-1 Owners
