shocks
Old Jan 9, 2008 | 09:39 PM
robert miller's Avatar
robert miller
Default shocks
What are the best shocks out there all round.
Old Jan 9, 2008 | 10:36 PM
Bounty's Avatar
Bounty
The answer is very dependent on what you're starting with, your budget, and what your goals for the car are...
I went with the Z06 shocks & sways and they are a HUGE improvement from the base non-magnetic ride suspension. Investment was minimal when factoring in new sways ($290) and used '04 Z06 shocks ($150) compared to the performance gains I experienced. Definitely rides like a different car.
I would recommend research and then ride in a few other Vettes with different setups to get a feel for you tolerance threshold in ride stiffness vs performance. It's a lot like exhaust...worst thing you can do is depend on someone else's opinion of good sound.
Hope this helps...
Old Jan 10, 2008 | 12:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hope this helps...
100% correct! I have the C6 ZO6 shocks on my 02 ZO6. They made a NOTICABLE difference! If you UP-GRADE to Z sway bars and C6 Z shocks,,,,,,you will be VERY happy!
Old Jan 10, 2008 | 02:31 AM
rustyguns's Avatar
rustyguns
good Bang for the buck!
Old Jan 10, 2008 | 02:48 AM
briann510's Avatar
briann510
Just remember if you are ever going to lower your car on the stock bolts do not use any year C5 or C6 Z06 shocks as they WILL bottom out. I just got rid of my stock shocks as they were horrible bottoming out after i lowered.
Old Jan 10, 2008 | 08:18 AM
calvette 11's Avatar
calvette 11
Default shocks
I have a 2000 and I get a lot of wheel hop drag racing.I have the basic
suspenion.What keep the wheels planted to the track.
Old Jan 10, 2008 | 09:46 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
KONI FSD's!
and LAPD has a special right now for $599 shipped in the For Sale section here on the forum!
Look up in the search tab here and it'll give you some good stuff on the KONI FSD's!
Thanks,Matt
Old Jan 10, 2008 | 09:56 AM
black98c5's Avatar
black98c5
I hear great things about Bilstein Sport Shocks. Especially if you're looking to lower the car. I'm getting a set in the next couple of months.
Old Jan 10, 2008 | 10:28 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Stiffer shocks would help, but a set of drag radials would help a lot more. Wheel hop is the number one killer of axels on C5's
Just about everyone at the local Corvette Challange run drag radials, even thoes with completly stock cars.
Old Jan 10, 2008 | 10:32 AM
HiVoltge's Avatar
HiVoltge
St. Jude Donor '08
I installed a set of Bilstien Sports om my 00 coupe... Along with Z06 sways and lowering the car, it makes a dramatic difference... Contrary to some other members comments, I don't find the sports too harsh...
They're perfect!!
Old Jan 10, 2008 | 11:02 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
If you have the money Penske or Moton should be at or close to the top of your list.
Old Jan 10, 2008 | 11:20 AM
briann510's Avatar
briann510
I just replaced my Z06 shocks with the Bilstein sports. I can tell very little difference between the 2 except for they aren't quite as harsh on the hard dips (actually a better ride with just as good of handling in my opinion). I blistered through the same 16 miles of twisties I run many times a week with TC/AH off to test them out and they seemed to let the outside tires stay planted better and the high speed run test all was just as well with them as the Z06 shocks.
I'm perfectly happy with them being able to take the car just as fast through twisties as with the Z06 shocks and have a better straight line ride with them.
Old Jan 10, 2008 | 12:10 PM
calvette 11
Default shocks
I use BFG drag radicals,and I get the wheel hop.
Old Jan 10, 2008 | 12:29 PM
calvette 11
They're perfect!!
do I have to lower the car to use these?
Old Jan 10, 2008 | 12:38 PM
bobbss's Avatar
bobbss
No.I have them with Z06 bars not lowerd and yes I like them.
Old Jan 10, 2008 | 12:51 PM
black98c5's Avatar
black98c5
No need to lower if you dont want to but the car just looks with it dropped a bit.
Old Jan 10, 2008 | 05:53 PM
Former Vendor
In that case I would go to a stiffer shock. If you still have your original shocks they may be going away. The shocks I use are adjustable for both compression and rebound. That way I can set them for drag or road racing and then set them for a decent ride home.
To shocks
Old Jan 10, 2008 | 06:36 PM
vsocks1's Avatar
vsocks1
I just bought QA1 adjustables - fronts are single adjustable and rears are double. Any suggestions on how to set them up for drag racing? Haven't installed them yet!
Old Jan 10, 2008 | 07:55 PM
robert miller
Default ttt
Thinks for all the help.. so need a good stiffer shock to get better runs in the 1/4 mile.2006 z06 shock, or the koni is the $ diff worth the cost.thanks for looking and ever one,s input..
Old Jan 11, 2008 | 01:07 PM
Former Vendor
Originally Posted by vsocks1
I just bought QA1 adjust ables - fronts are single adjustable and rears are double. Any suggestions on how to set them up for drag racing? Haven't installed them yet!
For drag racing you you would be better off with double adjustable fronts, however what you have will work fine.
I am not to familiar with the new QA1, but my shocks have 16 setting for compression and rebound.. my settings are:
Front: compression 12, rebound 4
Rear: compression 6, rebound 12
In your case I would start off (assuming 16 settings)
Front 6
rear compression 8, rebound 10
These are just suggested starting points. The settings are dependent on the car, tires and track conditions. You want the front to lift and the rear to squat slightly for weight transfer. You do not want the rear to squat to the extent that it throws off the camber decreasing tire contact with the track.
The rear setting also has to keep wheel hop under control.
Start off on the conservative side and work your way out
