SQUEALING Pulley?
Old Jan 10, 2008 | 09:02 AM
glerma's Avatar
glerma
St. Jude Donor '05
Default SQUEALING Pulley?
My 2000 6-speed convertible has an awful sqeal or squeak that changes with engine RPM. I do not think it is the belt. Has anyone else here ever had something like this happen in their 'Vette? I opened the hood and tried to locate it to no avail. Any ideas about what I am up against?
Old Jan 10, 2008 | 09:43 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Yes! I did and it turned out to be my AC Tensioner Pulley as well as the Idler Pulley!
I replaced it and it is all gone now!
The pulley's bearings got dry and started to grind!
Take a can of WD-40 -be careful- and get down ther with the supplied traw and give the pulley bearing (center) a shot and the idler pulley a shot of WD-40.
Do not spray the wheel or belt - just spray the center as it will pull it into the bearing and quiet it down, which will be a temp soloution but will identify the culprit!
Thanks,Matt
Old Jan 10, 2008 | 10:28 AM
David426's Avatar
David426
very common problem.. I did all my pullies at the same time along with goodyear gatorback belts
Old Jan 10, 2008 | 10:34 AM
glerma's Avatar
glerma
St. Jude Donor '05
Is this a labor-intensive or expensive repair?
Old Jan 10, 2008 | 10:58 AM
spider94r's Avatar
spider94r
Sometime it IS just the belt. Replace that before you go spending any real money.
That said, mine had a recurring squeak and I ended up replacing every tensioner and pulley, but it kept coming back. It wasn't until I replaced the harmonic balancer that it quit for good.
Old Jan 10, 2008 | 11:56 AM
bucwheat's Avatar
bucwheat
Easy to replace.
Old Jan 10, 2008 | 12:49 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
One or both could be the culprit, bearings go bad.
Napa has stock replacements for ~ $15 and $18, as well as better than stock replacements for ~$17 and $20 respectively.
To SQUEALING Pulley?
