Differential Oil Leak..Help.
Old Jan 11, 2008 | 01:13 PM
kg54trains's Avatar
kg54trains
Default Differential Oil Leak..Help.
I had changed my oil in my stock differential with 2 quarts royal purple and a GM additive. There was some flow that did come out after i filled the gear box. I have had a leak of the fluid at times when I go up or down my driveway that is a 30+ grade. Never oil as a standing puddle in the drive or at a parking stop. Could i have a leak as a result of a over fill or is this a bigger problem. The leak is not all the time and is noticed on my driveway hill.
Thanks for the help
Old Jan 12, 2008 | 09:12 AM
rws.1's Avatar
rws.1
The overfill could be leaking from the top of the diff out of the pressure relief valve.
If it has failed in the open position then the angle could be enough either nose up or down to permit the constant leak you see on a steep grade....
Just a thought... but that assumes you have already been under neath it again and ruled out gaskets and output seals and is the only thing I can think of that woul dlead to a leak only on a steep incline or decline
Old Jan 27, 2008 | 09:44 PM
landcaster's Avatar
landcaster
Cruising
Default Oil Leak
My car is also leaking. Its a 01 Z06, with 30.000 miles. Use the car for trips, autocross and the track several times each summer.
I noticed oil leaking from the left rear side of the axile so I had it checked out. My mechanic told me that when he took the plug out to check the level, air came out, like it was under pressure. The oil that I thought was leaking from a gasket was actually coming out of the pressure relief vent on top of the unit.
He cleaned the valve as best he could, checked the level, but didn't do anything else.
Is it usual to have the pressure build up? Should oil be coming out of the vent?
He didn't change the oil. Should it be changed and should I be using a high performance fluid?
Thanks for any help on this subject....
Old Jan 28, 2008 | 08:20 AM
vettenuts's Avatar
vettenuts
I was under the impression that air would go in, not out as the relief valve would purge air and not let it back in keeping a slight vacuum on the differential. Not sure if others have information on this.
Old Jan 28, 2008 | 09:53 AM
lucky131969's Avatar
lucky131969
The diff vent is in place to prevent pressure build up.
Old Feb 3, 2008 | 07:06 AM
Moonder's Avatar
Moonder
I will change my diff fluid this week, what do you guys think of royal purple? i am planning to use it .
Old Feb 3, 2008 | 07:48 AM
cruisemon's Avatar
cruisemon
Royal Purple is a good product, as are other all-synthetic lubes. Mobil 1 75W-90 comes OEM. Lucas will probably be most expensive or close. Price range should be about $8.00 a quart (Mobil 1) to about $15.00 a quart (Lucas). Limited Slip additive will be another $6.00 to $12.00 depending on brand.
Plan on lots of replies extolling the superiority of one brand/color over another and maybe even a couple of insults along the way for someone's choice of one over the other as this topic has been beaten to death, sometimes to the point the mods had to lock the thread.
Never let it be said that a 'Vette owner isn't passionate about his or her toy and the care and feeding thereof.
Charlie
Old Feb 3, 2008 | 12:47 PM
FL_Dave's Avatar
FL_Dave
Default Leak? Maybe not
The best way to find a leak is to squirt the differential with brake cleaner, drive a few days, then take a look. Everything will be nice an shiny except that little drip.
FWIIW, after fixing a differential side cover leak, I drove the car a few weeks, then noticed oil drops on the floor. Damn, I thought it was a re-do. Hate those... Anyway, it turned out that in draining the differential, I filled up the wire shield casing under the differential with oil and it leaked out over time. With a little luck, this could be your cause as well.
Old Jul 16, 2008 | 10:15 PM
imp zog's Avatar
imp zog
My '01 Z06 is a dedicated track car now, and I have the same problem, lots of fluid coming out of that relief valve. The valve is there to let hot gases escape, and keep the elements out. I am pretty certain that it does not make any kind of negative pressure seal, it is just a small plastic disc held in place over the breather hole with a very light spring, all within the floating metal cap. I pried mine off and am replacing it with a 3/8" oil line up straight up thru the trunk and then out thru the tail to exist behind the rear tail light with a small breather filter on it. There is enough of a neck on where the valve cap attaches to use a small screw clamp on the hose to make sure the leak does not continue. If it does blow up that far (which I highly doubt it will), I will install a catch can inline for it and have it drain back into the diff when it cools.
I hope this helps!
imp.
Old Jul 17, 2008 | 01:33 AM
rustyguns's Avatar
rustyguns
i took the valve out of the tube and have not had any problems since
stupid valve
we don't need no stinking valve
Old Jul 17, 2008 | 05:29 AM
patton's Avatar
patton
St. Jude Donor '09
stupid valve
right on
Old Jul 17, 2008 | 07:40 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FWIW, the differential does NOT hold 2 qts. The capacity spec from the shop manual is "1.94 qts.", so if you tried to pump in 2 qts. PLUS the posi additive, you overfilled it.
Don't feel bad, I did it once too...... I filled it right to the fill hole, and it oozed out the vent for a while.
Old Jul 17, 2008 | 12:54 PM
corvettebob1's Avatar
corvettebob1
stupid valve
I have mentioned this fix a number of times and each time I got flamed for it.
I found the problem back in 1999 and kepy it at bay by spraying the vent with brake clean and blowing air into the fill hole each year when bringing the car out of storage in Mi.
Now I live in Fl. so the car gets driven all year, just the same when I had the diff out in the spring I also removed the tabs valve and replaced it with a 6" long tube with a normal vent in the end.
Problem solved!
Old Jul 17, 2008 | 01:09 PM
verano29's Avatar
verano29
However, from what I've read the owners manual says 1.5 quarts and the service manual says 1.69 qts + 4oz of differential fluid (which is exactly what my z06 rearend took before it started spilling out).
To Differential Oil Leak..Help.
