Coolant change out
Old Jan 12, 2008 | 01:03 PM
cruisemon's Avatar
cruisemon
Default Coolant change out
Got all ambitious this morning, going to change coolant, can't get the petcock to open. It turns about 1/8 of a turn CCW but not 1/4 turn as I expected but I don't want to put a lot of muscle behind it and break it off. I think someone already did that since the petcock has a tab on it instead of the 1/4" drive.
So - should I just give it a little harder turn to get a full quarter turn or is 1/8 enough and there's enough crud in my radiator that the petcock is plugged? If it's plugged, what is involved in pulling the petcock to drain the radiator?
Charlie
Old Jan 12, 2008 | 01:05 PM
hotwheels57's Avatar
hotwheels57
Just pull the bottom hose...faster and more volume than the petcock...
Old Jan 12, 2008 | 02:38 PM
cruisemon's Avatar
cruisemon
D'oh. What REALLY makes me feel dumb about THIS is that I'm going to put stainless mesh covers on the hoses and would have had to pull it anyway. :o
Thanks!
Old Jan 12, 2008 | 02:49 PM
hotwheels57
...no reason to feel "dumb"...just another perspective of an easier manner to accomplish the task...
Old Jan 12, 2008 | 03:58 PM
American Hydrocarbon
Guest
Posts: n/a
Charlie
Don't force the petcock or it will break. Ask me how i know. If it only turns an 8th of a turn, try pulling it straight out a little at that point. It should drain then. If there is something keeping it from turning just remove the whole petcock then you will be able to see what's going on with it but I think the 8th turn is all you're going to get. What you break off by forcing it is the pin that guides it thru the opening/closing process via a small groove/ramp. If you can get close enough to the petcock you can see this groove/ramp.
Old Jan 12, 2008 | 08:14 PM
falcon5619's Avatar
falcon5619
Agreed. Once you turn it a little, if you can't pull it with your fingers get a little flathead screwdriver and gently pry it straight out until it starts to drain.
Old Jan 12, 2008 | 09:06 PM
cruisemon's Avatar
cruisemon
Pulling the petcock out was the key. Apparently it had been broken before because the petcock has a turn tab on it. I grabbed the tab with a pair of channel locks and pulled outward gently and it drained like a champ.
As it turns out the lower radiator hose is maybe 5" above the bottom of the radiator and wouldn't have drained the system completely.
I removed 10 quarts of coolant that actually looked pretty good - no cloudiness, etc.
Charlie
To Coolant change out
