Installing fast intake?
Old Jan 12, 2008 | 05:55 PM
JJ 86's Avatar
JJ 86
Default Installing fast intake?
When installing a fast intake on a 98 do you have to upgrade the coolant lines to the newer style (ls6 coolant lines)?
Old Jan 12, 2008 | 06:00 PM
vettenuts's Avatar
vettenuts
Yes, the coolant line that runs under the intake will no longer fit with the FAST in place.
Old Jan 12, 2008 | 06:03 PM
robert miller's Avatar
robert miller
has to be done..
Old Jan 12, 2008 | 06:04 PM
JJ 86's Avatar
JJ 86
Damn. Where can I purchase the coolant lines?
Old Jan 12, 2008 | 06:13 PM
vettenuts's Avatar
vettenuts
One of the forum GM parts vendors can get them for you. Also, once you install the front pipe (the rear are block off plates) you will need to use a rubber hammer and tap it down to clear the FAST. Install it first though.
Old Jan 12, 2008 | 06:17 PM
JJ 86's Avatar
JJ 86
Anyone have the part #'s? Is the bottom two part #'s what I would need to order? (This is from gene culley's website)
||--Genuine GM LS6 Intake Manifold--||
88894339 - Intake Manifold Only - 482.06!
Intake with coolant pipe and plugs – 521.54 + 15.50 shipping.
88894339 – Intake
12602544 – Coolant Pipe
12602540 – Coolant Plug Qty 2
Old Jan 12, 2008 | 07:31 PM
vettenuts's Avatar
vettenuts
Probably because you have to do this with the LS6 intake as well. Shoot an e-mail/PM to Gene, he is usually on the forum over the weekends.
Old Jan 12, 2008 | 09:34 PM
JJ 86's Avatar
JJ 86
Thanks for the quick info.
Old Jan 12, 2008 | 11:25 PM
chevy406's Avatar
chevy406
I just received my coolant pipe and plugs from Gene. He is a great source for decent price and quick shipping.
Old Jan 13, 2008 | 01:34 AM
ArKay99's Avatar
ArKay99
Also, make sure you have the valley cover cap bolts installed. If you keep the stock bolts you will crack the manifold when you tighten it down. The plenum is deeper that even an LS6 manifold.
Just making sure you've done this part.
Old Jan 13, 2008 | 09:01 AM
randy814u's Avatar
randy814u
Wheres a good source for the cap bolts? homedepot?
Old Jan 13, 2008 | 09:29 AM
vettenuts's Avatar
vettenuts
They come with the intake new. If you bought used, most guys don't bother to remove them from their car. They have to be button head bolts and will look like the photo below. I don't think HD has them. Bolt depot (internet does) and you should be able to find them in a lot of places. The black one comes from FAST (they tend to rust). The others are stainless replacements I bought. I ended up painting the FAST ones silver though.
Old Jan 13, 2008 | 09:31 AM
randy814u's Avatar
randy814u
yeah I bought mine used, so I will look around for the stainless ones I guess. Thanks, Randy
Old Jan 13, 2008 | 09:34 AM
vettenuts's Avatar
vettenuts
I think you can go with steel, just paint them up so they don't rust. If you can't find them locally, there is a place in Mass called bolt depot on line that has them but shipping to the left coast will take some time. Not sure what your time frame is.
Old Jan 13, 2008 | 10:18 AM
randy814u's Avatar
randy814u
I just went on the fast web site and ordered all new bolts. A little spendy, but it is all the bolts to install. Thanks for the help though. Randy
To Installing fast intake?
