Installed new shocks, now a clunking noise
Old 01-15-2008, 03:59 PM
BrianG01
BrianG01's Avatar
Default Installed new shocks, now a clunking noise
I installed a set of c6 z06 shocks on my car in early january and have been driving them around now for a few weeks. Sometimes I get a clunking noise going over bumps or potholes in the road, sometimes I dont...
Anyone have this happen to them as well? Any auggestions?
Old 01-15-2008, 04:00 PM
02gt350
02gt350's Avatar
was your car lowered before the install?
Old 01-15-2008, 04:12 PM
BrianG01
BrianG01's Avatar
Car is and has always been stock height
Old 01-15-2008, 05:27 PM
whitelite
whitelite's Avatar
Check all shock bolts for tightness and shock bushings for damaged or missing bushings. Also sway bar bushings where they attach to the frame have given me this problem before. I couldn't even detect play but replaced and the noice was gone.........
Old 01-15-2008, 07:24 PM
BrianG01
BrianG01's Avatar
I replaced the front sway bar bushings, but maybe I lined them up poorly
Old 01-15-2008, 07:49 PM
myvetteisfast
6th Gear
myvetteisfast's Avatar
Have had that happen before, it was a bushing that needed to be replaced!!!
Old 01-15-2008, 08:01 PM
BrianG01
BrianG01's Avatar
What kind of bushing?
It made no noise before the swap, so im wondering what the old shocks could have covered up...
Old 01-15-2008, 10:43 PM
BrianG01
BrianG01's Avatar
good night bump!
Old 01-15-2008, 11:18 PM
vincentjames501
vincentjames501's Avatar
I'm also interested in this. My car is louder over bumps after my koni install. But i just figured that was normal being that my car is much stiffer now.
Old 01-16-2008, 02:38 AM
striper
striper's Avatar
You might think you have the upper shock bushings as tight as you can make them. Trust me, they're not! If you can see them while the car is on the ground, you will see a little space somewhere. At least one of your shocks is not tight enough on the top mount. I installed Bilstein Sports on my Z. That's how I know!
Old 01-16-2008, 06:09 AM
BrianG01
BrianG01's Avatar
that is only on the front shocks correct?
The rears only had a bushing on the bottom if I remember correctly
Old 01-16-2008, 06:47 AM
jgump
jgump's Avatar
Old 01-16-2008, 10:41 AM
striper
striper's Avatar
I mean the top bushings, they are the same on all four shocks.
Old 01-16-2008, 02:20 PM
Richard Nogen
Richard Nogen's Avatar
I had this happen with a sway bar end link that was loose.
Old 01-16-2008, 04:04 PM
BrianG01
BrianG01's Avatar
Its so cold out now but I guess I have no other choice than to go check all the bolts
Old 01-16-2008, 09:05 PM
whitelite
whitelite's Avatar
Maybe a stiffer shock is highlighting another problem but if you replaced the sway bar bushings than my money is on something loose that you replaced.
As stated before, they may not be as tight as you think or maybe you missed something!!!!!
Old 01-16-2008, 09:24 PM
BlackZ06
BlackZ06's Avatar
When you installed the front shocks, did you have an Allen Wrench applied to the top end of the shock absorber (inside the engine compartment) as you tightened the nut in the wheel well ?? Ask me how I know this could be a problem ......
If you did not "lock down" the top of the shock with the wrench, as you tightened the nut in the wheel well the shock cylinder simply rotated, so you never compressed the bushing and achieved the correct torque on the top mount for one (or both) of the front shocks.
To Installed new shocks, now a clunking noise
Old 01-18-2008, 02:21 AM
striper
striper's Avatar
Old 01-21-2008, 07:22 PM
pimsleur
Cruising
pimsleur's Avatar
Default Amazing
You should practice what you preach
Old 02-25-2008, 07:36 PM
j84buick
j84buick's Avatar
Did you ever get rid of the noise?
Quick Reply: Installed new shocks, now a clunking noise
