Starting Problems
Old Jan 16, 2008 | 04:36 PM
04C5's Avatar
04C5
Default Starting Problems
Anyone have any idea what may be going on?? I drove my 04 coupe home from work yesterday without any problems. Started easily when leaving work, started easily when leaving the gas station and started easily when leaving another errand. Got home, parked in the garage. Had another errand to run 30 mins later....and she wont start! I get no codes in the DIC. All the accessories turn on but when I turn the key all the way to start the motor, nothing happens. No clicking, no dimming of anything, no codes! Any idea? I'm thinking my ignition switch may have taken a dump but I dunno...
Old Jan 16, 2008 | 05:26 PM
Irish Whiskey's Avatar
Irish Whiskey
You are not alone!! Mine just did the same thing!!! Pulled the switch and have ordered new switch and cylinder - will see what happens!!
Old Jan 16, 2008 | 08:44 PM
04C5's Avatar
04C5
Well, I dropped my baby off at the stealership...hopefully we'll both be back on the road soon!
Old Jan 16, 2008 | 09:48 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Was the security light on or flashing?
Old Jan 16, 2008 | 10:35 PM
65GGvert's Avatar
65GGvert
More likely the starter connection where the red wire from the battery connects. The nut could be loose, but more likely it's loose inside the starter. Take hold of the red wire near the starter connection and shake it and watch the bolt on the starter the wire is connected to. If it moves at all, you'll need a starter. You didn't say, and I didn't look, but if it's a manual, your clutch switch may be bad or misadjusted. Pump the clutch a few times and see if it starts. If it's an auto, forget that and make sure it's in park/neutral fully. Still think it might be the starter post though. Post what you find out.
Old Jan 21, 2008 | 02:13 PM
04C5's Avatar
04C5
FYI..... it was a bad ignition cylinder! something happened and it wasnt reading the security chip on the key! $250 later and she's good as new!
To Starting Problems
