A sparkplug's life?
Old Nov 29, 2001 | 06:22 PM
Red Rage's Avatar
Red Rage
Default A sparkplug's life?
I see sparkplug manufacturers making claims about their (usually "platinum") plugs lasting 60k to 100k miles. Is this true? Can I just forget about them for the next five years or so? How do I know when they really NEED to be replaced?
Thanks!
Old Nov 30, 2001 | 10:48 AM
Red Rage's Avatar
Red Rage
Default Re: A sparkplug's life? (Red Rage)
Okay, so I guess noboby has had a problem with sparkplugs going bad due to old age. That's a good thing. Maybe everyone just replaces them when the owner's manual tells them to.
I assume that symptoms of a bad plug are something like a rough idle, a drop in power and mpg, and maybe gassy smelling exhaust even after the engine has warmed up.
Any thoughts, anyone? :confused:
[Modified by Red Rage, 9:27 AM 11/30/2001]
Old Nov 30, 2001 | 11:32 AM
ScreaminDemon's Avatar
ScreaminDemon
For the price I would replace them aleast once a year,10 to 15,000 miles. More often if you race!
Old Nov 30, 2001 | 11:59 AM
Chris@SD's Avatar
Chris@SD
Well, I would scrap the Platinum plugs considering performance was not in mind when they put them in there but longevity! Get some copper plugs, like the NGK TR55's. A good guideline for me is to change them with every third oil change. I also use my trip odometer to monitor the performance of my engine. If I usually get xxx amount of miles on a tank and all of a sudden it starts to drop, I probably need a tuneup! :)
Hope this helps,
Old Nov 30, 2001 | 12:06 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
In general:
Relative to: change interval - spark delivery, and smooth efficient heat dissapation.
Platinum = longest longevity - good performance
Iridium = moderate longevity - great performance
Copper = short longevity - excellent performance
To A sparkplug's life?
