Fuel gage problem
Old Jan 19, 2008 | 01:23 PM
Grumman-aa1's Avatar
Grumman-aa1
6th Gear
Default Fuel gage problem
2001 c5 fuel gage reads fine until 3/8 of a tank is left. Gage needle will go to "E". Then when there is 1/8 of a tank left it starts working again. Always used the good gas as well as added Techron. Any thoughts would be appreciated.
Old Jan 19, 2008 | 04:55 PM
DeeGee's Avatar
DeeGee
The normal problem is sulfur build up on the fuel tank sensors causing bad readings at the gauge. The full fix, if Techron doesn't fix it, is to drop the tanks and change the sensors. Its a long job It m ay be worth persisting with the Techron for a while to see if you can clean it up
Old Jan 19, 2008 | 06:51 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Old Jan 20, 2008 | 09:15 AM
Grumman-aa1
6th Gear
Thanks, I'll continue the techron treatments.
Old Jan 20, 2008 | 10:21 AM
DeeGee's Avatar
DeeGee
Are you using a full bottle of Techron each treatment?
Old Jan 20, 2008 | 05:06 PM
LS1 REDBIRD's Avatar
LS1 REDBIRD
I had the same problem. I tried multiple bottles of Techron and Seafoam with no results. Someone on this board suggested I reset the PCM. Have not had a problem since.
Old Jan 20, 2008 | 08:55 PM
jaybar's Avatar
jaybar
Please explain "reseting the PCM"
Old Jan 20, 2008 | 09:35 PM
LS1 REDBIRD
http://forums.corvetteforum.com/show...ght=code+reset
Old Jan 20, 2008 | 10:20 PM
jaybar's Avatar
jaybar
Thanks for the reference. I am aware of how to reset or erase the codes. I though your were referring to some type of "re-flash".
But what the heck I will try the reset route.
Old Jan 21, 2008 | 01:13 AM
dmoore's Avatar
dmoore
A very common problem with the C5, I have used Seafoam and Techron both available at Wally World, cleaned up my problem. Make sure to always use a top tier gasoline.
You may have to use several bottles. If that doesn't work check the ground or it could be bad sending units which aren't cheap to replace.
Old Jan 21, 2008 | 09:45 AM
Grumman-aa1
6th Gear
Yes, I use a full bottle at fill-up. I know it says that it only treats 12 gallons. Maybe I need to use 2 bottles ?
Old Jan 21, 2008 | 05:00 PM
hornet7's Avatar
hornet7
Default Techron
WHERE DO YOU GET Techron?
Old Jan 21, 2008 | 10:27 PM
dmoore's Avatar
dmoore
Wal Mart or any local automotive store, Seafoam works just as well too!
Old Jan 22, 2008 | 11:03 AM
dgrant3830's Avatar
dgrant3830
There is also a GM software/firmware update for the onboard systems for the fuel gauge. I too was having issues and getting a specific code for the right tank sending unit. After the software update, no more problem.
Old Jan 28, 2008 | 08:51 PM
jaybar's Avatar
jaybar
How do you get "firmware update". I kind of assume you go the the dealer and he hooks up your car to his computer and downloads the data.
If this is the case what would be the usual cost of this service.
Old Jan 28, 2008 | 09:47 PM
dgrant3830's Avatar
dgrant3830
They charged me an hour of labor, $84, to do the updates that I provided to them...part number wise from the GM TIS system
http://tis2web.service.gm.com/tis2web
Old Jan 29, 2008 | 10:07 PM
big hoss 98C5's Avatar
big hoss 98C5
To Fuel gage problem
