How can reduced engine power be turned on?
Old Jan 20, 2008 | 09:33 AM
Fast one's Avatar
Fast one
Default How can reduced engine power be turned on?
What is an easy way to cause the reduced engine power to turn on? I would like to add a switch so that it could be turned on when needed like a valet key.
Old Jan 20, 2008 | 10:40 AM
BitViper's Avatar
BitViper
I bought a Cyclops ignition interrupter..but it wont limit the speed..just wont start
Old Jan 20, 2008 | 10:52 AM
FourG63 97GST's Avatar
FourG63 97GST
bit more difficult, but I usually reflash it and set the rev limit to 2500rpms
Old Jan 20, 2008 | 12:40 PM
DngrZne's Avatar
DngrZne
I believe there are some guys running a custom OS that allows a switch to be installed that switches the computer to a different fuel map when activated, but this would be better asked in the scan and tune section.
Chris
Old Jan 20, 2008 | 12:57 PM
robvuk's Avatar
robvuk
Probably best answered by a real tech but I'll bet you can do it with the wire from the engine temperature sensor. I believe the car goes into reduced power when it overheats. All you need is the appropriate resistor for getting an overheated readout. But there might be a requirement for knock sensors too. That would complicate things.
Old Jan 20, 2008 | 01:33 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I don't know which wire but you could tie it into the throttle position sensor.
Old Jan 20, 2008 | 02:41 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Let the knock sensors detect knock
clap some boards near one?
Old Feb 23, 2008 | 10:39 AM
Fast one's Avatar
Fast one
When the weather breaks in May I'll tie a switch into the system and if it works I'll post how it was done, this should limit the speed to 25mph until reset.
Old Mar 1, 2008 | 06:24 PM
corvette430hp's Avatar
corvette430hp
Let me know how this works out for you. I have had my car jump into that mode once when I fired it up it was like a old modle T performance wise 0-30 in like 10 seconds
Old Mar 2, 2008 | 12:26 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
ANY Throttle position sensor or Accelerator peddle sensor error will set it in a skinny minute!
Old Mar 3, 2008 | 09:37 AM
Fast one's Avatar
Fast one
Thanks Bill, I'll try this when it's warmer out. The accelerator pedal location makes wiring easy.
Old Mar 3, 2008 | 01:39 PM
LostCauseZ06's Avatar
LostCauseZ06
yep the TPS sensor is a PITA... lol. one of my wires had a tiny slice in it thanks to a thrown belt taking it out. never noticed and couldnt trace down why i was getting random "reduced engine power". you could have a button rigged up that interrupts the signal for a millisecond when started , that way it keeps it in reduced engine power until you shut it off and restart it. That way it is also still driveable.
Old Sep 5, 2024 | 08:14 AM
cajunboyz's Avatar
cajunboyz
From: South Lousiana (Cajun Boys with Bad ASS Toys)
Sorry wrong topic
To How can reduced engine power be turned on?
