Oil Can
Scotchbrite or stainless steel wool filter media will trap some of the airborn oil that sails through your PCV line. However, you will still end up with oil in your intake. To trap most or all of that airborn oil, filter media that was designed to trap oil very effectively is highly recommended. I talk about how and why coalescing filters are so efficient in this regard, in the article. The downside? Cost is one. A replacement borosilicate glass coalescing filter runs abot $25 and should be changed at least once per year, whereas a Scotchbrite pad can be cleaned and reinstalled - saving you money at the expense of the oil that escapes, ending up in your intake.
....your decision!
From what you said I understand it will help somewhat but not as good if I actually had some real type of absorbent filter media that will trap oil?
I may still buy one cause even if it helps a little it still helps.
Thank you.
Scotchbrite or stainless steel wool filter media will trap some of the airborn oil that sails through your PCV line. However, you will still end up with oil in your intake. To trap most or all of that airborn oil, filter media that was designed to trap oil very effectively is highly recommended. I talk about how and why coalescing filters highly are so efficient in this regard, in the article. The downside? Cost is one. A replacement borosilicate glass coalescing filter runs abot $25 and should be changed at least once per year, whereas a Scotchbrite pad can be cleaned and reinstalled - saving you money at the expense of the oil that escapes, ending up in your intake.
....your decision!
I have learned a lot from this forum from many of the adults here, too bad there are still a few bullies that need to harass a few who want to learn.
Yes I didnt need to read 15 pages of text for the simple question I asked, a simple quick answer would have been sufficent. I did download the PDF and when I get time I will read it in its entirety.
Thank you all for helping me.
Dave68 did not mention , but he well knows that location effects the effiecentcy of the oil catch can, which is why he as well as I mount the units far away from the engines heat ( not on the cylinder head) as possible.
But a simple "yes" will answer your question with a single "but", and that but is in how effective your catch can works in comparrison.
I see that you have a Next Level Performace oil catch can {tank}. Good machine work on that product ( I'm a retired journeyman machinist). I've been looking into adapting a coalescing filter into that particular catch tank. My brother in law is more into looks than function in his engine bay ( form over function) but I want to make it more functional for his track runs. Perhaps combining a cool can?
Always learning.
Why don't you take the time to explain your thoughts on the matter without continually being rude? You obviously know everything, why not take the time to help POLITELY educate others as well?
As far as the response about using a lawnmower filter on a C5, I started thinking.....this guy is having us on. That's why I though it must be a joke, and this guys is just playing with us. I arrived at this conclusion based on his previous post stating he was a member of other automotive forums, so surely he would not consider using a lawnmower filter on his car.
And no, I don't know everything. My knowledge is obtained through reading the service manual, reading the stickies,consulting with experts like ECS, A&A, RPM etc, and reading this forum about unique problems, solutions, and mods. Since I have a complete GM service manual on CD that includes all models from 1980-2005, I share/email and post info on a regular basis to those that need help, and of course, are willing to read said material.
I am typing this real slow because I dont think you can read fast.
The air filters that are used in Lawnmowers need oil in them to trap dirt but ARE NOT PRE-OILED, you oil them first and then install them in your Lawnmower. These Airfilters hold and trap oil in them very well. What I was thinking was installing the catch can and adding one of the Lawnmower filters that has not yet been oiled to the inside of the catch can because these filters really hold oil well. The oily air out of the PCV system will circulate through the catch can and have to pass through the Lawnmower filter that will catch the oil and put less oil vapor back into the engine.
Puts Crayons down.
Puts Crayons down.
Seriously the Lawnmower/Small Engine filters do hold and trap oil really good this is why I was thinking that this would work if installed in the catch can, just the filter media not the whole Lawnmower filter assembly.
If you have ever oiled and cleaned a Lawnmower filter you could see my point on how it may be an option to try.
http://forums.corvetteforum.com/sear...archid=7474879
I am sure you have lots of Modifications done to your car, did you read and research on how every part was made, why it was made, what exactly it does, why it does, what it is made out of, or did you just trust some suggestions by other members that have the parts installed and went by their reviews?
Forum member reviews are far better than any 15 page article, they can either destroy the reputation of the part or fully endorse the part and everyone buys it because of all the trusted reviews.
Always learning.
That is the reason people need to read as many threads and inputs as possible ... the more info you have the easier it will be to see the best way a mod is done.
