anyone ported a ls1 intake?
Old Jan 20, 2008 | 04:19 PM
ecoman's Avatar
ecoman
Default anyone ported a ls1 intake?
recieved a ls1 intake as part of a package deal.was told it has been ported to flow better than a ls2 intake. anyone had any experiance with a ported ls1 intake? looking for some feedback before i bother putting on the car.
thanks.
Old Jan 20, 2008 | 04:37 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
thanks.
Not too much on the LS1 being ported but here is an interesting article on LS series manifolds!
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
Thanks,Matt
Old Jan 20, 2008 | 06:30 PM
ecoman's Avatar
ecoman
thanks for the info but looking to see if anyone has had personal experience.
Old Jan 20, 2008 | 07:18 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What year LS1 manifold is it and is it truly an LS1. If it were a ported LS6, you would be better off. The only porting that you would see is some port matching and clean up in the intake openings and a little around the intake opening.
BC
Old Jan 20, 2008 | 07:25 PM
ecoman's Avatar
ecoman
its a ls1 not a ls6 you can see were the porting was done just curious if anyone has done this and their results. or do not bother trying and getting a ls6 instead, only have a cai,power duct with smooth coupler,cat-back and a superchips flashpaq tune.
Old Jan 20, 2008 | 11:08 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you have an LS1 on it now and you have an LS1 thats ported in hand, hell, stick it on and see if it makes a difference. It cant hurt and the O rings are only a few bucks.
BC
Old Jan 21, 2008 | 03:42 AM
dougbfresh's Avatar
dougbfresh
How do they know how well it flows? Did the person who ported it have it on a flow bench? Dyno it before/after??
Old Jan 21, 2008 | 07:51 AM
ecoman's Avatar
ecoman
just going bye what i was told.not sure were it was done or by who.
Old Jan 21, 2008 | 08:21 AM
randy814u's Avatar
randy814u
Like Bill said, stick it on and try it. It is a fast install, and you can reuse the gaskets. 2 hours max to find out if you feel a difference.
R
Old Jan 21, 2008 | 08:32 AM
ecoman's Avatar
ecoman
thanks for the replies,will give it a try once it warms up some.only 3 degrees here this morning not including the wind chill no garage.
Old Jan 21, 2008 | 02:33 PM
dougbfresh's Avatar
dougbfresh
You ought to get it dynoed before and after to see if it actually did anything. I would guess it would not. I'd almost be afraid of carving on a composite manifold.
Old Jan 21, 2008 | 03:04 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
dougbfresh
The composite that our manifolds are made of is easy to work with. You just have to be careful not to make deep gouges. Its a lot like working with body filler. The right tools make all the difference.
Ill be carving up my FAST 90 here soon to make it breath a little better. I may not get all the results of a TONY Fast but, I will make surely make some improvements! I will show some before and after pics. Wish me luck.
BC
Old Jan 21, 2008 | 03:47 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The manifold is sand casted 40% glass filled nylon. It is a semi crystalline structure...I would not try to alter this manifold unless you have specifically controlled speeds and feeds, because the glass can cause heat degradation and ruin the strength of the manifold..
Old Jan 21, 2008 | 04:37 PM
American Hydrocarbon
Guest
Posts: n/a
thanks.
Are you sure that it is an LS1 ?
Old Jan 22, 2008 | 05:42 PM
ecoman's Avatar
ecoman
Yes its a ls1, can see the grind marks where it was ported.
To anyone ported a ls1 intake?
