Ok, I have a 2000 A4 with 3.15 gears, Corsa Pace Car Exhausts and a K&N Filter. I have about $3G to spend....how would you recommend I proceed and in what order??
- Headers
- Cam
- Gears/Converter
- New CAI intake
- Manifold
- Tune (obviously)
- etc??
What are your goals? Are you looking for a beefy bottom end or peak HP.
If it were me:
- Stainless Works headers w/ performance curve high flow cats ($800 installed)
- Cam (consult your tuner for specs) w/ upgraded valvetrain & tune. should be in the neighborhood of about $2000 installed for all the goodies.
- (If you have $150 left over, get a shaner ported throttle body)
If it were me:
Thanks for the reply RadioFlyer.....I'm not sure my goals are REAL clear right now. I dont plan to track the car, so its more of a hobby (this is not my DD). I'm into visual and performance gains. I'm really looking for something that will sound BAD *** at idle and throw my hard into my seat when I want it to...and look great doing it! I'll look into your suggestions - thanks
From: Marlton. Increasing performance one speeding ticket at a time! NJ
If it were me:
C5LS103CAT 2001-2004 Corvette, 1 3/4" Headers and X-Pipe w/Converters $1,846.41
Err, I think you left off a g-note on the headers there RadioFlyer. Please tell me I'm wrong and where I can get Stainless Works headers installed for $800.
Cam is a good option, many are running installed specials for 2k installed and tuned. Your not going to get all the cam can offer though without headers. The cheapest set of headers are pacesetters, you can get them coated, and a catted x for about 1K, plus install. Take out the cats and it's much cheaper.
I've been quoted about 2700 for 3.42 Z06 diff and 3200 stall installed. Since you already have 3.15's, you may save a few hundred and go to 3.73's in your existing carrier. That leaves you room for a Vararam and tune.
negative. The headers themselves are ~$320 (depending on shipping destination) here on the forum (pm "tstar" for details) The Cats from performance curve I got were $80 shipped for 2 3"metal matrix w/o O2 bungs. Installation was the most expensive part: $400 for installation including welding of the AIR fitting.
The headers originally had fitting issues but since several forum members aided in the re-design of them we all get a nifty discount.
In all fairness, those are SSAutochrome, not Stainless Works. Not quite the same thing. Still, a good value if your willing to deal with all the welding and potential fitment issues.
Most shops will tell you Headers, Gears and a custom air intake, like a Vararam would be the first thing.
It sounds funny to say this, but $3000.00 is about the minimum for mods now days, for a vette anyway.
For the $3000.00 or just a bit over, you should be able to get the following:
Headers: $800.00 to $1000.00 - used probably
Vararam - $300.00
Gears: 3.42's - $550.00 to $850.00 - used
Dyno Tune: $400.00 to $500.00
Labor: $500.00 to $600.00 - probably too low.
Do it yourself if you have another car while you work. The job is NOT that difficult as long as you're careful.
Everything after heads/cam is simple (except for the tune!).
I did my h/c swap myself. The rest of the car was 100% bonestock (didn't have Ti exhaust at the time), and I gained 60whp after tune. I mean, 100% stock except for no airlid (ziptie mod during tune). I still had MAF screen, original plugs & wires (68k miles) and coolant flowing through the throttle body. No porting of intake manifold, throttle body or anything. Cost? $2000 for heads, $400 for cam, $100 for gaskets, $250 for ARP studs and $180 for new timing.... that runs ~$3000
Tune was around $500.... BUT, the car ran fine without the tune.... just too rich. What does this mean? You can drive it until you can get it tuned.
If I can do it, anyone can.
Now, I am on a mission to hit 400whp without going to headers or CAI. lol..... wish me luck
My installer told me that there minimal fitting issues (no trimming required) The only note is that for my 97 I need a new oil dipstick mount because the old one was attached to the exhaust manifold.
Originally Posted by 02gt350
cam/ heads, do yourself
I wish i had the tools/time/skills. Install costs more than the cam alot of the time.
Installing a cam in an LS-1 is the easiest cam swap Ive ever done. I bought my cam kit for 700ish and the labor would have been 1200 bucks. Did it myself and bought a stall converter. On the LS-1 you dont even need to take the intake off. You older guys remember the old small blocks huh? Tell me you never got the distributor 180 off..... Do it all yourself!
