Best Cold Air Intake?
Old Jan 24, 2008 | 11:57 AM
hotwheels57's Avatar
hotwheels57
Originally Posted by C5Bagger
Is the Blackwing concidered a cold air filter?
By itself, no it is not, but it might be considered an improved "Cooler Air Intake" filter (you can then use the same abbreviation CAI ).
It might allow more air into the engine by its design vs oem. If you want to make it "colder" you'll need to enclose the filter, completely eliminating the warmer air intake from the engine compartment. The Z06 cars are improved over the C5 cars with more air flow through the front bumper. If you own a C5 you can somewhat mimic that by eliminating or cutting open your fog light enclosures for additional air flow.
Do a search this forum (in the red banner) in C5 Tech, using keywords "ice box cover". It's a molded ABS (or carbon fiber) enclosure that is specifically designed to fit snugly over the BLACKWING filter. You then have to cut the radiator shroud beneath the filter/cover to allow cooler or colder air into the intake.
I tried to find an image of the cover, but was unsuccessful. I'm not sure if it's available any longer.
Old Jan 24, 2008 | 12:08 PM
DAYUIZ's Avatar
DAYUIZ
That sounds like what my Vortex Air box does. Bottom breather that pulls air from outside the engine bay and from under the front of the car.
I didn't buy from this website, I'm only linking to it as an example. http://www.corvettegarage.com/produc...-corvette.html
-Steve
Old Jan 26, 2008 | 11:35 AM
mcv's Avatar
mcv
Not "cold air" unless ductwork is added to get air from outside engine compartment directed at filter element.
Old Jan 26, 2008 | 12:33 PM
Cary's Avatar
Cary
IMHO, rather than do the above might as well go with a Breathless Performance Vortex CAI, and you can order a precut shroud to match.
... just my 2 cents
