These are some common problems that should've been resolved in an older C5:
Column lock failure (steering wheel locks-up): If it's an auto (A4), then the dealership should've removed the mechanism and installed a block-off plate. If it's a 6-speed (MN6), the dealer cannot do the same, so make sure the previous owner installed a Column Lock Bypass (keeps the locking pin in the retracted position).
Leaky differential gaskets: These should have been replaced, as factory seals leaked by 20,000 miles.
Door lock modules: When they fail, arming the car with the remote fails to lock one or both doors. This is a relatively simple installation, but make sure both door locks work.
Fuel gage/sender unit malfunction: Make sure the fuel gage reads accurately when the tank is below half-full. Earlier years had problems.
Oil pressure sender unit. If this fails, the oil pressure gage will show 80 psi. If so, the sender unit needs replacement.
Horn not working when the steering wheel center hub is pressed - probably a relay; I need to get mine fixed.
Some people have said don't get a C5 earlier than 2001, although 2001 are the most common for sale. I found the thread on problems, but would still love to hear from you 99 FRC owners.
The Corvette Forum does not condone any activity which is dishonest, unethical or immoral with that said, members are prohibited from offering free Carfax reports to their fellow members via their agreement.
Although such activity does not directly affect the forum, it does promote a procedure which the forum deems to be inappropriate.
Carfax is used as an example, but, the rule will apply to any similar activity or business.
