Paging Nick Agostino
Old Nov 30, 2001 | 11:50 AM
BLACK-HT's Avatar
BLACK-HT
Default Paging Nick Agostino
I was curious as to what you are running as a fuel set-up on Wade's Corvette for the direct-port you guys are running. Are you using your fuel pump setup up that make, plus inline or boost a pump. I have added a second stage to my car and I want to spray it but wanna be safe first.
Old Nov 30, 2001 | 11:54 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Paging Nick Agostino (BLACK-HT)
Nick is away at the PRI show for a few more days. Make sure to bring this post to the top next week so he can check it out when he gets back.
I do not know too many details about Wade's direct port setup but I do know it is a complete seperate fuel system that draws from the OEM fuel tank.
Old Nov 30, 2001 | 12:52 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: Paging Nick Agostino (MattG)
I would also like to know about such a fuel system. A second line from the tank is a good idea.
Only thing is I will have to do it myself!!:(
No chance to bring the car to US to have it done :(
Maybe Nick can give me the parts and instrutions??
PICS??
Michael
[Modified by Austrian Vette, 5:54 PM 11/30/2001]
Old Dec 3, 2001 | 09:15 AM
BLACK-HT's Avatar
BLACK-HT
ttt
Old Dec 3, 2001 | 03:08 PM
Nick Agostino's Avatar
Nick Agostino
The fuel system on Wade's car is a seperate one. We are using the factory one for engine only and a seperate pump and line with regulator for the No2. We do sell this fuel system with our(TNT) direct port kit as a package. The fuel system draws fuel from the factory tank in a different location than the stock pump. This is the real only way to have 100% control over the No2 tunning(fuel side) than if you are running off the factory lines and pump; this also has the fuel capacity to make over 1000 hp(flywheel).
Hope this helps.
Old Dec 3, 2001 | 04:54 PM
BLACK-HT's Avatar
BLACK-HT
Default Re: Paging Nick Agostino (Nick Agostino)
So do you think your Walbro dual intake pump will be enough for a 250nx wet shot, I really dont want to have to set up a different fuel setup if I dont have to.
Chris
Old Dec 3, 2001 | 05:27 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Chris the stock pump is good to about 525RWHP, a single Walbro in-tank should handle 600RWHP, and the dual in-tank Walbro setup should handle about 800RWHP. Of course when you're spraying a 250 shot I hope you're running race gas.
The system Nick described doesn't sound that bad since it uses the stock tank with just a seperate fuel pump. If you went ahead and did that you wouldn't ever have to worry about upgrading your fuel system again. :)
-Jeremy
P.S. Also if you're interested in this rollbar let me know:
http://forums.corvetteforum.com/zerothread?id=193847
Old Dec 4, 2001 | 12:50 PM
BLACK-HT's Avatar
BLACK-HT
Default Re: Paging Nick Agostino (Godspeed)
Nick could you please get me some more details along with pricing, I like that idea better because I dont have to run a seperate fuel cell, if I understand you right.
Chris
Old Dec 4, 2001 | 12:56 PM
Austrian Vette
Chris
Would like to know more details and pricing also!!
Thanks,
Michael
Old Dec 4, 2001 | 05:54 PM
BLACK-HT's Avatar
BLACK-HT
Default Re: Paging Nick Agostino (Austrian Vette)
ttt
Old Dec 5, 2001 | 02:20 AM
Nick Agostino
The factory fuel cell must be removed and a bulkhead fitting installed. The complete fuel system is available from tank to fuel solenoid and includes regulator as well as braided lines and all fittings, there are no rubber of hose clamps in this system. It is available in low and hi pressure systems for about $750USD and only recom. this for No2 applications.
Hope this helps
Old Dec 5, 2001 | 05:01 AM
StrtracerX's Avatar
StrtracerX
Nick,
I am also interested in the Seperate fuel set-up. It seems like I def. need it.. I just put a TNT kit on my car and when we first spray the car the car dies and then picks up.. It seems that the N2O setup is starving the motor when we first hit it and then as the pressure (65 PSI) builds back up, it is fine.. Pumps not putting out the volume.
I have roughly only 497hp in the motor with the stock 97 fuel system. Right now I'm using the fogger set-up and may switch to the direct port in the future. Would I need the High or Low pressure set-up?
X
Old Dec 5, 2001 | 12:23 PM
Austrian Vette
Nick,
that setup is in my near future, along with my stroker.
For now (heads/cam +150 wetshot NOS), your dual fuelpump setup seems enough for me, and would be great, especially as I can leave it in the car for the stroker later and add the extra fuel setup for 300 hp directport NOS!!
What is the price for the dual pump setup, what mods are needed to use them? Or do they come as a bolt on set??
Want it as simple as possible.
Thanks a lot,
Michael
Old Dec 5, 2001 | 10:40 PM
StrtracerX's Avatar
StrtracerX
ttt
Old Dec 6, 2001 | 12:10 AM
Nick Agostino
Default Re: Paging Nick Agostino (StrtracerX)
If you are using the TNT twister kit I would recomend the hi pressure fuel system, when you go to the direct port(fogger) system you can hi or low pressure. The diff. is what system you have, the person(s) you have helping you tune it and so on, the TNT kit we sell (fogger) is set up with a low pressure system and works great.
The biggest thing on a No2 system is the 'tune-up', there are many diff. ways to get there so taking a little info from here and there can be a BIG problem!
The dual pump set up in only available right now for the F-body and are working on one for the C-5 as we speak. The single intanke setup for the C-5 should be good for 550 rwhp.
[Modified by Nick Agostino, 10:13 PM 12/5/2001]
To Paging Nick Agostino
