Granatelli MAF Sensor Question
Old Nov 30, 2001 | 02:59 PM
SteveSz's Avatar
SteveSz
Default Granatelli MAF Sensor Question
I'm thinking of adding this to my Christmas wish list and have a couple of questions:
1) Does it really boost HP and how much should I expect? My MN6 C5 has a Twinflo intake and Corsa exhaust but is otherwise performance stock.
2) Are the effects seen on a car that hasn't had a performance reprogram of the PCM?
3) If you replace the whole MAF sensor, I presume the additional mod of MAF Ends no longer applies? In other words, MAF Ends are used simply to upgrade the stock MAF sensor, right?
Thanks for your help :seeya
Old Nov 30, 2001 | 03:24 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
Default Re: Granatelli MAF Sensor Question (SteveSz)
I added one to my car.
I believe it gave me some increase in power, mainly because it does flow more that the stock unit.
But what really helped me was adding the MAF Translator.
the MAFT helped me tune the PCM for the added airflow that I was now getting.
with my mods and the stock MAF W/screen removed, I was running about 15% lean.
the Granatelli was running me about 5% rich. It think it was better to tune the car from a 5% rich condition than 15% lean.
I dyno'd the car at corvettes @ carlisle, it had 317Hp and 327ft-Lbs Torque.
that was running 5% rich (before I got the MAFT) I should have a little more power now.
:cheers:
[Modified by RPOZ4Z, 2:27 PM 11/30/2001]
Old Nov 30, 2001 | 03:50 PM
SteveSz's Avatar
SteveSz
Default Re: Granatelli MAF Sensor Question (RPOZ4Z)
Thanks RPOZ4Z,
What is a MAF Translator? Are you saying you didn't really see any improvement with just the MAF Sensor alone? I thought that b/c the MAF Sensor mod increases power by increasing airflow that just like with an intake and exhaust mod, you shouldn't need to do anything else and the PCM will relearn and adjust on its own. Am I wrong?
Old Nov 30, 2001 | 04:04 PM
RPOZ4Z's Avatar
RPOZ4Z
It's hard to tell how much of an increase I saw.
I installed the donaldson filter at the same time as the Granatelli MAF.
a MAF translator plugs into the harness between the MAF and the PCM.
it is used to "tune" the air fuel ratio. there are two adjustments, one for cruise and one for WOT.
you will need a diagnostic program like ease or autotap to tune the MAF.
the PCM dosn't compensate for the increased airflow from adding a ported MAF. that's why the granatelli is a "recalibrated" unit.
which is why I was 5% rich with the Granatelli and 15% lean with a Ported stock MAF.
[Modified by RPOZ4Z, 3:10 PM 11/30/2001]
Old Nov 30, 2001 | 05:18 PM
MDL-01C5's Avatar
MDL-01C5
Lemme ask you this-- I ordered the Re-cal/re-loc MAT sensor---
where the hell does it go on my car?
Sounds stupid, I know, but the 2001 is different, so I'm not sure where to put it...
:cheers:
Old Nov 30, 2001 | 05:27 PM
RPOZ4Z's Avatar
RPOZ4Z
Default Re: Granatelli MAF Sensor Question (MDL-01C5)
I think on the 2001 the MAT sensor is built into the MAF.
you really don't need it anyway.
I had one and went back to stock. :cheers:
Old Nov 30, 2001 | 06:08 PM
Jim 47's Avatar
Jim 47
Steve:
I'll try to answer your questions based on my experience. I too have a 2000 FRC with the Granatelli MAF and twin K&N filters. I found that changing from the Stock MAF and filter to the Granatelli and dual filters increases the RWH by 16 HP. I later added a timing tricker which plugs into the air bridge between the MAF and the Thorttle body. This "fools" the computer into thinking the air charge is always cold, which pumps more fuel into the engine.
I have not reprogramed my PCM. And, yes the MAF ends are for the stock MAF meter.
The car runs very smoothly and strong, and definately feels like more HP.
Old Nov 30, 2001 | 06:10 PM
MDL-01C5's Avatar
MDL-01C5
So you're telling me that they sold me this thing Knowing I couldn't use it? :confused:
Old Nov 30, 2001 | 06:12 PM
Gandalf's Avatar
Gandalf
I changed mine at the same time adding the BPP vortex and power duct. Air flow through the MAF is definately better then the stock one. I know GMS sells two versions of this for the 2001 there is one tuned for cold air boxes and one that is not incase you do not change your air intake. I do not really know what the major difference is between the two i image it is just some program changing. they are both the same price, so it can't be anything to major
Old Nov 30, 2001 | 06:21 PM
Red Rage's Avatar
Red Rage
This MAFS/MAFT issue is starting to sound like a lot of other mods -- they work great on 1997-99 C5's, but don't really help (and maybe hinder) performance on 2000+ C5's.
MDL-01C5, if that MAFT doesn't work for you, I might be interested in buying it.
Old Nov 30, 2001 | 06:29 PM
Supercharged's Avatar
Supercharged
From: 26 NM out the 304 radial of the ORD VOR Illinois
Default Re: Granatelli MAF Sensor Question (Red Rage)
Red Rage, Don't you mean 97-00 vrs. 01-0?
Old Nov 30, 2001 | 06:51 PM
MDL-01C5's Avatar
MDL-01C5
Sounds good-- mail me:)
Old Nov 30, 2001 | 07:00 PM
Red Rage's Avatar
Red Rage
Default Re: Granatelli MAF Sensor Question (Supercharged)
Yes, I probably do. Now the ZO6 guys are wondering why the Donaldson Blackwings boosted hp on their 2001's, but kills some hp on their 2002's. It's a mixed-up, crazy world chasing horsepower. :crazy:
MDL-01C5, I'll email you tonight or tomorrow. I have to run right now. :seeya
Old Nov 30, 2001 | 08:39 PM
C5XTASY's Avatar
C5XTASY
Default Re: Granatelli MAF Sensor Question (Gandalf)
I had a problem with my GMAF on my 2000 and sent it back under warranty. Granatelli sent me a brand-new unit calibrated 10% rich. I called them because I thought they had made a mistake. They told me that the new base Granatelli calibration is 5% rich for all stock air filters and 10% rich for all aftermarket filters (I run a Blackwing), cold air or not. They said the LS1 is a lean running engine and their R&D showed better performance with these calibrations. Previously, they recommended a 5% rich calibration for cold-air intake systems only. As the Granatelli comes already ported and screenless, it seems to me that the new calibrations adjusting PCM input for this might make it a more universal "plug and play" device than previous versions. Running a little rich, if indeed you would be, is better than running lean. I understand that power changes are far less dramatic as air/fuel ratios move around a little due to temperature, humidity, etc., in a rich zone rather than a lean one.
Ed
[Modified by C5XTASY, 6:43 PM 11/30/2001]
Old Dec 1, 2001 | 12:22 AM
DAP's Avatar
DAP
Default Re: Granatelli MAF Sensor Question (C5XTASY)
I also have an '01 with the Vortex/GMS/LAPD high flow duct/coupler. The first GMS MAF was for stock boxes, and pinged on the high end. They sent me a 5% rich version and now I have no pinging, and "wiggle room" for other leaning conditions-like a full exhaust :reddevil
Not sure if I gained much power, but like the 5%-but miss the airbridge in the middle (I think it flows too much air at lower RPMS causing mild off throttle bucking below 2K)
Mr. G told me himself the 10% is for power adders...
Old Dec 1, 2001 | 01:29 AM
C5XTASY's Avatar
C5XTASY
Default Re: Granatelli MAF Sensor Question (DAP)
How long ago was this and how did he define "power adders"? The reason I ask is they told me about the new GMS 5% standard for stock air filters and 10% for any aftermarket filters, about two weeks ago. I am running a Donaldson (non-cold air), WCC Powerduct and coupler and an A&A mod and X-pipe on the exhaust. Though better than lean, I also do not want to be running too rich. However, my car is now in storage and will not be able to try the new GMAF until spring.
Ed
[Modified by C5XTASY, 11:32 PM 11/30/2001]
Old Dec 1, 2001 | 10:34 AM
DAP's Avatar
DAP
This was about 4 months ago. Also, 10% rich sounds REALLY rich. He mentioned NOS/turbo/supercharger. I have gotten some interesting responses from them before.
I've read where the CPU guys define slightly rich for power and detonation free as 2-3%. The 5% should be right all the way up to exhaust for efficiency-and still be rich.
Also, for what it's worth-I have the cold air box on my Vortex, which would "cancel" your exhaust work (I know boys, it's a stretch :rolleyes: )
I get no pinging in hot weather with coolant in the 220's, and my gut instinct says I'm still running a little too rich for power.
I have hopes FLP's new C5 full length headers, high flow cats, X pipe, and a Z06 exhaust will lean me out for power (and lose 50 pounds of dead exhaust weight!!). I will hopefully have/install them by March.
To Granatelli MAF Sensor Question
Old Dec 1, 2001 | 10:35 AM
Red Rage's Avatar
Red Rage
Does anyone know how to tell the 5% GMS MAF from from the 10% MAF by part number or by looking at it. The GMS part number I have is 350112.
C5XTASY, do you know anyone in town with AutoTap or EASE? If not, maybe TPIS or Doug Rippie (DRM) can help me out cheaper than buying one of those.
:seeya
[Modified by Red Rage, 8:37 AM 12/1/2001]
Old Dec 1, 2001 | 03:14 PM
C5XTASY's Avatar
C5XTASY
:seeya
Red Rage,
No, unfortunately I do not know anyone with the equipment. Let me know if you find someone.:)
Also, my MAF came with 10% rich scratched in the plastic and with an attached sheet indicating the richness calibration.
Ed
Old Dec 3, 2001 | 12:48 PM
SteveSz's Avatar
SteveSz
Default Re: Granatelli MAF Sensor Question (Jim 47)
Thanks Jim,
Your answer was the closest to the question I asked. But just to repeat, can anyone tell me if I put a Granatelli MAF Sensor (NO Translator) on my 2000 FRC which already has a twinflo intake, will I see any difference in performance WITHOUT doing any reprogramming?
Thanks :seeya
