Yank converter users
Old Jan 26, 2008 | 05:53 PM
smask04c5's Avatar
smask04c5
Brit2001 look at my sig. I went with the SS 3200 and could not be happier. Yank makes an excellent product.
Old Jan 26, 2008 | 06:08 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by brit2001
I have a vision for my car and a 3200 stall fits that vision.
and that's what it's all about
Old Jan 26, 2008 | 06:34 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
While it's not a bad idea, you may not need an auxiliary cooler to keep your temps down. As an example, I've been quite happy (in the hideous Texas summers no less) with a lower temp thermostat and lower fan cooling temps. That setup has been able to control trans fluid temps generated by street driving and the occasional trip to the dragstrip just fine. I told myself I'd put one in if it looked like I needed one and so far I haven't. Enjoy your new setup.
Old Jan 26, 2008 | 07:32 PM
Purerock105's Avatar
Purerock105
I've been running a Yank SY3500 w/3.42's since 2002 with no issues. I
ran the B&M 24000 cooler upon install and only got rid of it when I
replaced the radiator with a Dewitts.
I've also ran drag strip and road course as well.
Get ready for a whole new car.
Old Jan 26, 2008 | 10:12 PM
One Nut's Avatar
One Nut
Well Yank ss3600 & 3:73's highest temp in stop & go traffic in Kali last summer 95+ deg day I saw 223* it runs mostly at 208 I have a B&M cooler looking at me saying hey stupid why am I not being put to work I would like to hard plum the the cooler lines I dont like barbed ends and hose clamps are there special fittings for the cooler and the factory lines also can it be plumed in line with the raidator
Old Jan 27, 2008 | 09:48 AM
C5XTASY's Avatar
C5XTASY
Originally Posted by tblu92
Pro & cons to bypassing the stock radiator trans cooler when installing the extra cooler-I tried it both ways and mine runs cooler with the radiator cooler bypasssed--
That would work fine in a warm climate like California, where I believe you're at. Now, if in a cold climate, and you run your car in the early spring and late fall, I believe it may be hard on the transmission because of the extremely long warmup times in cold temps. That radiator transmission cooler also provides a stable, quicker warmup cycle, useful in cold weather, rather than just natural transmission-generated heat...JMHO.
Ed
Old Jan 27, 2008 | 12:15 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
If you're not going to the track, and it's only a street car, why change the converter? I had a ZO6 3.42 rear recently installed on my 03 coupe, and retained the stock converter. I drove an 03 coupe with 3.42's, and a 3200 Yank, and didn't like it at all. So far, I'm happy with what I have. Find someone with a 2800, a 3200, or Mike Mercury's GM tc, and see what they feel like first in person.
Old Jan 27, 2008 | 02:32 PM
TopFuelTim's Avatar
TopFuelTim
My DD has a Yank SS3200, with just the stock trans cooler. Suffers a bit of gas mileage loss around town, no difference on highway because of lockup.
Only problem with temps is in 95 plus degree weather. Got up to 233 degrees one day in Atlanta rush hour traffic on 285. Normally stays at or under engine temp.
The converter was installed by the previous owner, who raced it successfully at Atlanta Dragway for a year. It would cost far more to replace it with a stock converter than it does to leave it in.
The upside is it accelerates QUICK! That part is a lot of fun. We have also run Yank Converters in our race cars for years without a problem.
Tim Glover
Old Jan 28, 2008 | 09:57 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Ed
--- Tom
