Coils --- Different?????
Old Jan 25, 2008 | 04:42 PM
LT70ZR91's Avatar
LT70ZR91
Default Coils --- Different?????
I have a 99 with a stock LS1. I was wondering if the coil packs are the same as the LS2, LS3, LS6 and LS7. Do they all mount the same on the Corvette?
Old Jan 25, 2008 | 06:01 PM
thetorch's Avatar
thetorch
I think it works out like this:
Center bolt LS1 and LS6 are plug compatible, but some of the coils are different. e.g. car, truck. Some of the coils have a different bolt pattern where the coil bolts to the bracket. The bolt pattern where the bracket bolts to the valve cover is the same.
LS2 is plug compatible with LS1/6 but uses a different bracket to mount the coils to the valve cover.
