Cigarette lighter/power source not workin
Old 01-26-2008, 02:33 PM
babalu95
babalu95's Avatar
Default Cigarette lighter/power source not workin
My cigarette lighter and power source will not work on my '99. I went straight to the fuse box but since it doesn't have any printings on it, I can't ID which one is which. Anyone have any suggestions? Please advise.
Old 01-26-2008, 04:19 PM
byronhunter
byronhunter's Avatar
In my '02 service manual, IP fuse block, Possible fuse #1, or #7. Yours could be different! HTH
Old 01-26-2008, 06:46 PM
babalu95
babalu95's Avatar
Thanks. I'll have to try and locate my manual. Hopefully it will disclose the same info.
Old 01-26-2008, 07:10 PM
BlackZ06
BlackZ06's Avatar
If you mean the AUX wiring located in the passenger footwell, and your cigar/cigarette lighter next to your ashtray ....
If you need to look at an on-line copy of your owner's manual ... go too .....
https://www.mygmlink.com/pdf/go2cont...99corvette.pdf
Fuse locations are on page 370 of 426 (using Adobe page count) or 5-94 (using GM page numbers) and the Cigarette lighter fuse is in the group on the far lower right, the Cigarette lighter fuse is the one at the bottom left of the block. On my 2001 it is a 20 AMP fuse, you'll have to pull yours to check the correct Amp rating.
Old 01-26-2008, 07:50 PM
COFireFRuby
COFireFRuby's Avatar
It seems I always forget to plug in the ashtray lighter when I R&R the console benzel. Just a thought.
Old 01-26-2008, 08:29 PM
2MFFZo6
2MFFZo6's Avatar
have you installed a shifter or anything??
Old 01-27-2008, 12:58 AM
timemender
timemender's Avatar
Here is a link for the 1999 Corvette Owners Manual in PDF format.
Save it to your computer after it downloads.
NOTE: Other years are available - Simply change the "year" towards the end of the link. AFTER you click on it and after it appears in the address window of your browser.
Old 01-27-2008, 01:30 AM
babalu95
babalu95's Avatar
I mainly use the one on my console for my breathing nebulizer. To and from work. They both went out so I'm assuming it's the fuse. Will look up the PDF manual.
Old 01-27-2008, 02:01 AM
BlackZ06
BlackZ06's Avatar
Guys, the OP said that his cigarette lighter AND HIS AUXILIARY POWER SOURCE is out ....
It ain't that he didn't plug in the lighter after taking apart the console ....
To the OP ... see my post #4 above, I tell you exactly where the fuse is located, along with the same link timemender gave you in post #7 ......
Sheesh ... does ANYBODY around here read previous posts ??????????
Old 01-27-2008, 09:48 AM
mrm1149
Support Corvetteforum!
mrm1149's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
babalu95 >> if you wind up needing receptacles, I have them for both locations. Just pm me but sounds like simply a fuse thing to me.
Old 01-27-2008, 11:10 AM
j curtiss
j curtiss's Avatar
I have a '99 C5 hardtop and the console power receptacle fuse is #1 and the fuse for the cigarette lighter in the ashtray is #7. If you remove the cover to the fuse block located in the passenger footwell, you'l find a handy fuse ID diagram pasted to the inside of the cover.
Old 01-27-2008, 02:01 PM
American Hydrocarbon
Guest
Posts: n/a
Then not to leave any stones unturned
Pull out the ashtray and stick your fingers around behind the lighter socket and see if it came loose from the socket or the connector is not snapped on to socket assy. It's a C5 anything's possible
To Cigarette lighter/power source not workin
Quick Reply: Cigarette lighter/power source not workin
