GTECH How accurate?
Old Nov 30, 2001 | 10:09 PM
robiferretti's Avatar
robiferretti
Default GTECH How accurate?
How accurate is the GTECH pro you drag racing guys? Slower or faster then real time? :seeya
Old Nov 30, 2001 | 10:15 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: GTECH How accurate? (robiferretti)
rob, no pro......but traps HIGHER by 2-4 mph, and ET's .1-.2/10 higher.....
So i am told......
Old Nov 30, 2001 | 10:18 PM
Fast_Toys's Avatar
Fast_Toys
When I tested mine at the track, the ET was within a tenth of a second but the MPH read 6 high on a 109 MPH car.
Old Nov 30, 2001 | 10:19 PM
GaryZ06's Avatar
GaryZ06
I have used it many many times at the track and is was very accurate.It was off by no more than 1/10th of a second and most of the time it was off by a mere 1/100th of a second.The MPH is little higher due to the track averages the last 66 ft and the G-tech gets the MPH at the exact end of the 1/4 mile.The key to get accurate times is make sure it is level,straight and on tight.
Old Nov 30, 2001 | 10:20 PM
MelloYellow's Avatar
MelloYellow
Default Re: GTECH How accurate? (Fast_Toys)
GTECH calcs actual trap speed, ET's calc average trap speed over the final X number of feet, hence the difference. It's accurate.
Old Nov 30, 2001 | 10:26 PM
Sir Sel's Avatar
Sir Sel
Default Re: GTECH How accurate? (MelloYellow)
G-tech measures speed at the end of the quarter. Not the trap speed which is the average of the last 66 feet.
[Modified by Sir Sel, 9:28 PM 11/30/2001]
Old Nov 30, 2001 | 11:44 PM
robsvette's Avatar
robsvette
robf, also keep in mind that you must run it in a flat 1/4 mile road surface.
Old Dec 1, 2001 | 12:25 AM
79er's Avatar
79er
Default Re: GTECH How accurate? (robsvette)
I have one also and have found it very accurate. The really great thing about the G-tech is that is always accurate to it self, so by doing a few runs and writing down the times you then can try mods to see if there is a difference.
Old Dec 1, 2001 | 12:26 AM
C5Cemo's Avatar
C5Cemo
It's good to hear that the G-Tech works that well. I've been wondering about it.
I've currently got a Vericom VC2000 for the same purposes. I've been real happy with it. Really bulky compared to the G-Tech, though.
:cheers:
Old Dec 1, 2001 | 12:42 AM
jimhild's Avatar
jimhild
Default Re: GTECH How accurate? (79er)
We sure agree with your comments.
The repeatable readings are great. It works excellent for determining the real impacts of specific modifications.
Use ours all the time.
Old Dec 1, 2001 | 03:17 AM
robiferretti
Thanks guys a certain person was telling me that just because i get #'s with a gtech doesn't mean i can repeat those at the track. Looks like someone may be apologizing come spring :yesnod:
Old Dec 1, 2001 | 05:31 AM
Austrian Vette's Avatar
Austrian Vette
Yes, the mph are liitle higher, because it measures the actual top speed!
ET´s are very accurate.
I found out,that if you have much wheelspin, then it comes little off and shows more ET than you really get.
When I tried my new TC and tranny on my runflats I was spinning all the way from first gear to the mid of second gear.
The Gtech showed 13,4 and the actual time was 12,9.
On my ET streets run with nearly no spin it was accurate about 1 tenth then!
Michael
Old Dec 1, 2001 | 10:30 AM
levrac68's Avatar
levrac68
Very accurate as they have posted. I have also found that the HP measurment is also accurate to within 5 as long as you know the exact weight of your car. It is very sensitive to the point that if it isn't exactly pointed straight down the hood of your car, your reading will be way off. It helps to start from the exact same point in the road too, if you want to check any HP or 1/4 differences from mods.
Good Luck. :cheers:
Old Dec 1, 2001 | 11:48 AM
Gen II's Avatar
Gen II
Default Re: GTECH How accurate? (levrac68)
As others have said, it is accurate. In fact, balanced against cost, it is amazingly accurate.
Old Dec 2, 2001 | 12:42 AM
C5_PIG's Avatar
C5_PIG
Default Re: GTECH How accurate? (Gen II)
Rob when I tested it, it was on the money. The only thing that was off was the MPH, told faster MPH. Robsvette had the same results.
Old Dec 2, 2001 | 01:39 AM
maninblack's Avatar
maninblack
Default Re: GTECH How accurate? (jimhild)
hmmm, mine is still in its box frm last year, havent really had a chance to use
it yet :smash:
Old Dec 3, 2001 | 07:47 AM
rwj383's Avatar
rwj383
GTech all over the place. dont bother with one. just spend the $$ on ScanEase or Autotap and read the power #'s from the computers accelerometer!!
Old Dec 3, 2001 | 10:10 AM
Paradigm's Avatar
Paradigm
Default Re: GTECH How accurate? (rwj383)
The gtech works fine but I have to agree with spending the bucks on diagnostic software being a longer term, better purchase.
To GTECH How accurate?
