double roller timing chain, what's the point???
Old Jan 29, 2008 | 07:35 PM
slow ride's Avatar
slow ride
The Rollmaster I reused from my h/c setup on my 383 broke two links in the center. I doubt it had more than 10k on it. Lucky I cought it during a oil change on the plug magnet. I now use the ktech single with new gm sprokets and the GMPP chain damper.
Old Jan 29, 2008 | 08:17 PM
vettenuts's Avatar
vettenuts
Wow, you are the second person I have seen have this issue with this setup. Do you know if the chain was an IWIS?
Old Jan 29, 2008 | 09:16 PM
smask04c5's Avatar
smask04c5
Crane 144984 billet timing set, no clearance issues on install, quality part
Old Jan 29, 2008 | 11:29 PM
slow ride's Avatar
slow ride
Yes it was an IWIS So is the single Katech single chain, but I would hope it's of better quality. I posted about it a while ago on ls1 tech so you might have seen it over there.
Old Jan 29, 2008 | 11:45 PM
thetorch's Avatar
thetorch
Was it a single or double roller Rollmaster?
Old Jan 30, 2008 | 12:28 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
A weak chain or one thing a lot of guys don't check when installing new sprockets, sprocket alignment. If its off, it will induce a bending load in the chain and fatigue it. Design loads for chain are typically 10% of their load capability to ensure long life. Not sure what rating the engine designers use (GM, Ford, etc.) but that is the general rule of thumb.
wow, I hope my LS2 chain doesn't fail. I just slapped it on and didn't really check the alignment. The car has 58k on it and maybe 3k on the chain
Old Jan 30, 2008 | 05:50 AM
vettenuts's Avatar
vettenuts
Ahhhh, may be the same one I am thinking of then.
vettenuts's Avatar
vettenuts
Did you install new sprockets? Most of the time they will line up but its best to verify with a straight edge.
Old Jan 30, 2008 | 12:21 PM
bikeone's Avatar
bikeone
I have the Crane Cams 144984 billet double timing set as well, no clearance issues, no problems.
Old Apr 16, 2008 | 09:17 AM
Rob's 73's Avatar
Rob's 73
Add one more broken LS2 timing chain.
When I was FI'd my stock cam bolts loosened up. At that time I put on a new top ls2 gear and chain. I didn't touch the bottom gear. After maybe 3000 miles, I ditched the FI and did H/C with the same gear set. About 1000 miles later with 2 days of HPDEs the chain broke. What chain do I use now? LS2 with dampner? I didn't have a dampner before.
I haven't pulled the heads yet to assess the damage. I know I have several bent valves. I'm hoping I can slap on my LS6s heads and get some driving time in. I really don't want to do a new motor right now.
Old Apr 16, 2008 | 09:47 AM
vettenuts's Avatar
vettenuts
There are harmonics in the timing chain that will tend to wrap the chain around the bottom sprocket, i.e., the chain doesn't release correctly. The damper prevents this from happening. I believe it is approximately 4,000 RPM. A HPDE is the perfect setting for this to occur. I would suggest that if you plan to do HPDE, the damper is a must.
Old Apr 16, 2008 | 11:42 AM
C5XTASY's Avatar
C5XTASY
This is a little frightening. I had an LS2 chain installed in mine when I had the H/C, etc., setup installed. I did not install the dampener because chain tension was good following installation. I was told the dampener was necessary if there was a little loosness in the chain, which mine did not have. I do not race the car but play with it sometimes, as everyone does. I sure hope this never happens to me!
Ed
Old Apr 16, 2008 | 12:10 PM
  #33
Rob's 73's Avatar
Rob's 73
You will probably be fine. My chain had some play but my research indicated it was pretty normal. It was loose out of the plastic. My buddy just installed one on his new motor and said it was pretty loose as well. He did install the dampner. I didn't know about the dampner when I did my H/C.
If my pistons are salvagable, I am going to install my stock LS6 heads with some new springs and a new LS2 timing set with dampner and hope that I can get a few more HPDEs out of the motor. I really don't have the extra cash right now to buy a new motor.
Old Apr 16, 2008 | 12:18 PM
  #34
vettenuts's Avatar
vettenuts
Not sure what year your motor is, but the older tan GMPP damper is no longer made from what I have been told. If you have a newer block, the LS2 damper "may" fit, depends on bolt spacing. Also, if you are handy you could make one out of a solid block of material, not sure if Delrin would work but there should be an oil resistance block you could make it from if necessary.
Old Apr 16, 2008 | 12:51 PM
  #35
NassyVette's Avatar
NassyVette
What about the new dampner makes it not fit? I see an ls1/ls6 dampner advertised on thunderracings site, is it the older or newer one? Says some blocks may need to be drilled and tapped? Is this worth it in your opinion (vettenuts)? Can it even be done safely with the engine in the car? All this timing chain crap has got my head spinning...I was about to just order the comp single adjustable and forget about it, but now I hear that it doesn't come with a thrust bearing....they show one in the ad so what gives? Hell at this point I might just get an LS2 set and throw the cam in straight up...
Old Apr 16, 2008 | 01:45 PM
  #36
vettenuts's Avatar
vettenuts
Unfortunately, the bolt spacing is different between the LS2 damper and the GMPP LS1/6 damper. If you find one, and your block isn't drilled, it comes with a drill template.
If you plan on HPDE's, I think it is worth it in my opinion.
Old Apr 16, 2008 | 01:56 PM
  #37
Rob's 73's Avatar
Rob's 73
My motor is a late 03 LS6. Which one do I need?
To double roller timing chain, what's the point???
Old Apr 16, 2008 | 02:08 PM
  #38
JR-CRUZN-C5's Avatar
JR-CRUZN-C5
Cloyes double roller no issues - 4 years
JR
Old Apr 16, 2008 | 02:41 PM
  #39
Last C5's Avatar
Last C5
If I open up my 01 LS6 am I probably going to find the holes already drilled or not? If not, are there specs for drilling the holes? Drilling the front of my block has a certain pucker factor to it, but the car is used for the track and the dampener sounds like a good safety factor.
Old Apr 16, 2008 | 02:53 PM
  #40
vettenuts's Avatar
vettenuts
Couldn't tell you, mine is 02 and was drilled. As for an 03, old style damper. The later 04 blocks I think have the LS2 spacing.
